Priority Start Question
Old Apr 4, 2006 | 04:55 AM
Pappi's Avatar
Pappi
Default Priority Start Question
I just purchased a priority start pro for my 05 c6 but haven't received it yet. My question is can you hook up a battery tender with a priority start installed?
Old Apr 4, 2006 | 09:06 AM
PaBlueCoupe's Avatar
PaBlueCoupe
St. Jude Donor '06-'07-'09
Good question.
Old Apr 4, 2006 | 10:49 AM
Lowlead's Avatar
Lowlead
The priority start is basically invisable to the car until the battery voltage drops to the pre-determined trip level. So , yes, you can use a battery tender.
I use a device called a Battery Minder, it's very similar to a battery tender in that it provides a 1 amp charge then switches to a float mode when the battery tops-off. Once it switches to float mode, it stays in float mode until the unit is disconnected and re-connected.
If the car has an episode of DBS, the float charger hasn't got enough poop to prevent it and the battery voltage will decline. At some point, the PS will trip and disconnect the battery as it should.
Old Apr 4, 2006 | 11:05 AM
vette4db's Avatar
vette4db
I apologize for being green in this area, but what is the purpose of the battery minder if it can't prevent the battery from going dead?
Again, I am sorry if the question comes across as sarcastic. Its not the intent.
Old Apr 4, 2006 | 11:48 AM
Lowlead's Avatar
Lowlead
Generally these float charges are sold as a method of keeping a stored battery up to snuff (ie boat, ATV, RV) to counter the normal self-discharge of the battery. Not really intended to deal with the rate of discharge that DBS can impose.
I was fortunate (?) enough to catch my last DBS while hooked up to the DVM. It registered a 1.2 amp draw. Normal draw for the car is around 30ma (.03 amps).
The float current being supplied to the battery is well below the 1.2 amp of the DBS event.
Old Apr 4, 2006 | 03:13 PM
rm50's Avatar
rm50
2020 C8 of the Year Finalist - Unmodified
I am still looking for someone to post a picture of a priority one installed. It seems to install it the negative and positive posts are very close together.
Old Apr 4, 2006 | 09:05 PM
boosted_z06's Avatar
boosted_z06
What is forgotten is if the battery is low to not start the car it still though preserves all the settings and using just the battery tender would prevent low battery
The PS though every time is disconnects the battery not only forces everything in memory to get erased but also would cause the PCM back to a total relearn state but worse is all the internal smog tests would get blown out and car would appear to have failed those tests plus all those tests would have to run until they are in a passed state again
Old Apr 4, 2006 | 09:16 PM
VET4LES's Avatar
VET4LES
I don't know about all of that except the window indexing but it sure beats having DBS when all of those thing would happen anyway. With the tender you must hook it up or plug it in each time where the PS is completely passive.
Old Apr 4, 2006 | 11:48 PM
Lowlead's Avatar
Lowlead
I've had DBS 5 times now and have never lost anything from car's memory other than the window indexing. The PCM reset via battery disconnect used to happen on my 2002 GMC Sierra, and you knew it when it did. The car even had to relearn how to idle.
That has never happened in the C6 nor have I heard (read) that it's happened to anyone else. Not sure what you mean about "internal smog tests".
Old Apr 13, 2006 | 06:51 PM
Paulct's Avatar
Paulct
Nothing is lost other than the windows indexing. Do people just make this crap up and post it?....
Old Apr 13, 2006 | 07:01 PM
dbradley's Avatar
dbradley
Never had DBS, but have the Priority Start on there so "if" I'm on the road it will start in the morning.........
Old Apr 13, 2006 | 08:09 PM
VET4LES's Avatar
VET4LES
Good idea. I have thought of the same thing.
Old Apr 13, 2006 | 08:24 PM
Hoonose's Avatar
Hoonose
Interestingly enough DBS rarely, if ever, strikes on a road trip!
I think the reason is that you have obviously been driving a bunch on your trip and charging the battery. And you usually drive daily while on the road.
If DBS is to occur, the car must sit long enough for the battery to drain to zero, and that has not been seen on your typical road trips.
Now, when your battery's already old and weak next year.....
And since you have '06, no DBS possible anyway!
Some dead batteries with '06 MN6, but virtually none with A4!
http://forums.corvetteforum.com/poll...pollid=1500606
The MN6 numbers are a little better than demonstrated, since quite a few '05 MN6 people voted on '06 dead batteries by mistake.
Old Apr 13, 2006 | 09:04 PM
PaBlueCoupe
The original question was about the priority start/battery tender combination.
Has anyone hooked up both??
Old Apr 13, 2006 | 11:36 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Yes, I have.
I hooked up the Priority Start after the unwarranted '05 DBS Panic.
I usually leave the car garaged for most of the winter so the Battery Tender Plus which I used on my last Corvette was hooked up over most of the winter.
Hooked it to the positive and negative posts of the battery with the Priority Start still hooked up. The first time I did it, I removed the small black wire of the Priority Start from the connector.
Took the car out on an Indian Summer day and afterwards hooked up the Battery Tender Plus again, but this time without removing the small black ground wire of the Priority Start. Checked with them about this and was told that it should be OK. No problems.
Still have the Priority Start hooked up, too lazy to remove it and with spring here, no need for the Battery Tender Plus. So yes, you can use them both.
To Priority Start Question
