Having new wheel issues..
Old Apr 7, 2006 | 12:13 PM
valdeztke's Avatar
valdeztke
Default Having new wheel issues..
I put on a set of new C6 Black Motorsports on my C6. Well the left rear tire is losing air at about 1 psi 2 days. I had it taken into the wheel shop and they could not find any leaks. What could it be?
New wheels and new tires...
We noticed a smaller leak when we tightened up the valve stem.
Is there another way to check other than putting the stem and tire back on the stock wheel?
Old Apr 7, 2006 | 12:15 PM
midnite902's Avatar
midnite902
I would suggest unseating and reseat the valve in the valve stem and obtaining stanless valve stem caps with gaskets.
Old Apr 7, 2006 | 12:16 PM
valdeztke's Avatar
valdeztke
I will give it a shot in the AM
Old Apr 7, 2006 | 02:05 PM
vetdude's Avatar
vetdude
Did the shop install the o-rings for the tire pressure sensors properly? The old "deeping the wheel/tire assembly into the water tank" process works wonders too. Good luck!
Old Apr 7, 2006 | 02:10 PM
valdeztke's Avatar
valdeztke
Well I do still have 4 lil O rings left in my box that came with the new wheels. Small black rubber O rings... do they go somewhere on the new wheels becuase they didnt make it onto the new wheels... could that have something to do with it ...
Hmm well not the best tire people NTB ...
Old Apr 7, 2006 | 05:03 PM
BIGGGIE's Avatar
BIGGGIE
St. Jude Donor '05-'06-'07-'08
bingo
Old Apr 7, 2006 | 05:23 PM
99 torch red vette's Avatar
99 torch red vette
that is why they work at a tire shop because they are not the smartest folks.
Old Apr 7, 2006 | 05:33 PM
Vette Nut's Avatar
Vette Nut
I have never re used the O-rings. I alway get new ones to put in, i figure its better than having to risk damaging a wheel during dismount because of a leak
Old Apr 7, 2006 | 07:25 PM
30YR W8T's Avatar
30YR W8T
This might be a pain, but if you want to find out where the leak is do it the old fashion way. Spray a mix of soap and water on the wheel around the rim and valve stem. After this is done watch and look close for bubbles. If you see them then you know where your leak is. If you don't find anything on the front, then you need to check the backside in the same manner. The other sure fire way is to take the wheel and tire off and submerge a section at a time in water, you will find the leak.
Old Apr 7, 2006 | 08:44 PM
VET4LES's Avatar
VET4LES
I found a slow leak in a new wheel buy submerging it in my swimming pool. It was a casting flaw.
Old Apr 7, 2006 | 10:20 PM
30YR W8T's Avatar
30YR W8T
Now that is something I had not thought of.....great idea
Old Apr 13, 2006 | 11:41 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
I think you just answered both questions.
To Having new wheel issues..
