Brake conversion question
Old Apr 8, 2006 | 04:14 PM
EuroRod's Avatar
EuroRod
Default Brake conversion question
When converting to the Z06 brake package, is it necessary to also swap brake lines? I've been told that the standard brake lines and the Z06 brake lines carry the same GM part number. Anyone know if this is true. If not, then do I need to order Z06 brake lines? Thanks for the help.
Old Apr 8, 2006 | 05:12 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Yes, I believe the rear lines neeed to be longer. StopTech makes braided lines that fit.
Old Apr 8, 2006 | 05:41 PM
EuroRod's Avatar
EuroRod
Thanks.
Old Apr 9, 2006 | 12:59 AM
dgcarver's Avatar
dgcarver
The mounting flange for the line to the caliper is too big on the stock lines. The SS braided lines look much better. You will love the way it stopes with the new Z06 kit and SS lines.
To Brake conversion question
