C6 column lock problems
Old Apr 12, 2006 | 02:48 PM
lciesemier's Avatar
lciesemier
4th Gear
Default C6 column lock problems
I have a 2005 C6 with 1200 miles on it. 3 weeks ago it would not start; an indicator appeared on the computer saying, "Service Column Lock". I had to have it flat-bedded from my garage to the dealer where it is still awating a part. Anyone else experience this??
Old Apr 12, 2006 | 07:28 PM
tedsredC5's Avatar
tedsredC5
Default column lock?
I guess call me stupid....I've read a few posts about column lock on the C6....mine does not have this wonderful feature? Am I really missing something? Or do the C6's actually have a column lock on them?
Old Apr 12, 2006 | 07:50 PM
VET4LES's Avatar
VET4LES
If you have a 05 you have a column lock. The 06 eliminated it.
Old Apr 12, 2006 | 07:57 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Was the battery low or dead?
Old Apr 12, 2006 | 08:24 PM
Pontiaker's Avatar
Pontiaker
Freaking wonderfull, you think they would have learned the first time around with the C5 fiasco....GM really needs to pull their head out of their ***.
Old Apr 13, 2006 | 10:19 AM
scrannel's Avatar
scrannel
Column lock was mandated by law -- only in '06 was GM able to convince government lock was useless.
Old Apr 13, 2006 | 12:20 PM
Hoonose's Avatar
Hoonose
Do you have MN6 or A4?
'Service Column Lock' warning shows frequently with any dead battery situation, and there is usually no actual column lock problem. There was one report of '05 column lock failure, but nothing like with C5's.
Old Apr 13, 2006 | 01:15 PM
rbranvold's Avatar
rbranvold
Column lock was removed from automatics during the C5 run (I think in 2001.) It was removed from all Corvettes in 2006. Many 2005 column lock problems seem to be associated with DBS.
Old Apr 13, 2006 | 01:21 PM
Hoonose's Avatar
Hoonose
That's probably not true.
Although the DIC warning 'service column lock' comes up frequently with any dead battery, and not just DBS, it is just a general code that shows up, and generally there is not a column lock issue.
Now, it may eventually turn out that there is a relationship between the column lock and DBS, but so far that has not been shown.
Old Apr 13, 2006 | 02:52 PM
Minkster's Avatar
Minkster
They have now been removed from all MN6 C5s too via recall. Just had my '00 FRC done two weeks ago. I think they may still be in the '05 C6 because it's part of the BCM S/W, and that will take recoding to fix. In other words, if it comes, may be a while .
Old Apr 13, 2006 | 06:45 PM
tedsredC5's Avatar
tedsredC5
Default column lock
I don't know......my 2005 vette coupe does not have, nor has it ever, had the column lock on it......I bought it Sept 10 2004.....turn the wheel all you want.....it won't lock up.
Old Apr 13, 2006 | 06:49 PM
Hoonose's Avatar
Hoonose
MN6 only.....
Old Apr 13, 2006 | 07:34 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
THERE IS NO COLUM LOCK ON ANY C6 !!!!!
Old Apr 13, 2006 | 07:56 PM
Hoonose's Avatar
Hoonose
Oh yes!
My '05 MN6 definitely has a column lock!
Old Apr 13, 2006 | 08:00 PM
VET4LES's Avatar
VET4LES
Interesting. I wonder what causes my 05 MN6 C6 Steering Column
to lock when I shut it down. Maybe I should take it to the dealer.
Old Apr 13, 2006 | 08:15 PM
youngs98's Avatar
youngs98
Umm when I got out of my 05 ten minutes ago, the column definitely locked.
Old Apr 13, 2006 | 09:03 PM
So nsane's Avatar
So nsane
I have had two DBS ever sense I have made sure the steering wheel is locked it has not happened again. Guess I am lucky. I am betting on a programming flaw in the computer that checks to see if the steering wheel lock is in the locking position. This is only an opinion not based on any facts.
To C6 column lock problems
Old Apr 13, 2006 | 10:16 PM
VET4LES's Avatar
VET4LES
I wish it was that easy but in my case in over a year and 7500 miles I have not had DBS and I never make sure the steering wheel is locked. It probably locks half of the time. I just shut it done and get out of the car, it locks sometimes and other times when it is not lined up it does not.
Old Apr 14, 2006 | 12:08 AM
Hoonose's Avatar
Hoonose
In December one month of specifically not locking the column and no DBS.
Old Apr 14, 2006 | 02:41 PM
lciesemier's Avatar
lciesemier
4th Gear
Default thank you for replies
Thanks for all the replies, I have to differ from those who say there is no column lock. Sorry, the car is at the dealer having the actuator for the column lock replaced. My vehicle is a 2005 C6 Z51 and it does have the infamous column lock. The dealer told me they could not disable it-"it is hard-wired into the system". The battery is fine and has been fine. Does anyone know if it is possible to have this "feature" disabled??
