Supercharger
2006, Z51 MN6. I want a forced air induction that allows the following:
1 Stock hood
2 Quiet
3 Not too hard on the engine
4 Known long life, low or 0 maintenance.
Thos of you who have done this to there c6 or c5, your input, mileage on systems, problems and price would be very very helpful indeed.
I am not out for the most horsepower, just a nice clean, well built system that can deliver extra power without tearing the motor up.
Lockshed: A&A did a fantastic job on my ProCharger install, which headers?? Best of luck and keep us posted with your results.
http://www.lingenfelter.com/pack_cor_c6.htm
Please let me know if I can answer any questions for you,
Thanks,
Ed
A positive displacement blower on the other hand makes low end torque like a 427, always on tap. That I expect, is why virtually (yes there are exceptions) every production supercharged auto made uses a positive displacement (Roots/Lysholm type ...such as Magnuson) supercharger. Take a look at Mercedes, Cadillac (all GM), Mustang (all Ford), etc.
Turbos have traditionally had substantial lag while the exhaust gases build up and are essentially exhaust-driven centrifugal superchargers ...but in recent years they've employed smaller and staged impellers to reduce (eliminate maybe) lag and come up quick enough to be more like a positive displacement blower. Spo you see those in production cars ...Bentley, etc., etc. ...our friend Ed from Lingenfelter can comment here. Assuming that Ed can tell you he's overcome lag and can give you low end ...then the concern I would have here is cost. When I see Twin Turbo I think in terms of big $$$.
So my belief is 1) Forget ProCharger, Paxton, Vortec, etc. unless all you do is drag, 2) Install a Magnuson and get a new hood ...they look cool anyway, or 3) See if Ed has something to sell you with his turbos.
OK all you ATI Procharger guys ...I'm bracing myself. What say you?
A little hair raising ride in a ProCharged C6 may quickly change your thinking. No flame here, it may not be for everyone.
Now what's that about making all the power above 5000 RPM? Please don't compare our cars to Mustangs!
Many people make similar comments which I never understand. I think that's whey they put that shift thingy in the center console. If you are trying for max acceleration why would you ever not put the car in the correct gear for the speed you are starting from and then shift when you run out of rpms in that gear?
If you don't believe me, tell me why there's not a major auto manufacturer using a centrifugal supercharger from the factory ...OK I am thinking there was a little Cutlass in the 70s? Think about it - centrifugals are the cheapest and easiest to install, yet every manufacturer I can think of is using either a roots, lysholm, or a turbo setup with multi-stage light impellers.
Nice try on the "shift thingy" big guy. You really got me on that one! For most of us though, street driving is not about winding your car to the red line on the way to Kroger. It's about cruising in fourth and having instant punch at the gas pedal ...not requiring a downshift, clutch in, get RPM up, pop clutch. On the other hand, c5grandsport's dyno sheet does point out low end gains - thanks for that. And OK, you got gain at all points - but you're still getting waaay more at high RPM. I think you'll find a positive displacement blower shifts the whole curve vertically and near-equally across the spectrum. More low-end ...and OK before you say it, the posi gives up some on the top end to the centrifugal. That's why the centrifugal is best for dragging and the posi for street ...and maybe (not sure here - too dependent on design) ...the multi-stage turbo might be best all around ...at a price.
If you want low rpm boost so you don't have to shift fine with me. I prefer to be in the max horsepower band when I get on it.
I crack myself up! Anyway I have an ATI procharger with a 4.50 pulley(I can go smaller but not now). Dynatech longtube headers into magnaflow exhaust.That gets me 508/482. I bought a set of replica rims 18x9.5 with Nitto 555R 305/35/18 and that does the trick on the streets. Next trick is a set of 3.42 gears to replace the 2.72's in there now (plus the upgrade in sway bars)
