Side marker lamps
Old Apr 23, 2006 | 11:49 AM
pharmpod's Avatar
pharmpod
Default Side marker lamps
How do you remove the front lamp assembly from the driver's side?
Thanks, Benny
Old Apr 23, 2006 | 12:44 PM
calemasters's Avatar
calemasters
Thanks, Benny
Front Side Marker Lamp Replacement
Preliminary ProceduresRemove the front wheelhouse liner to gain access to the front side marker lamp.
Front Side Marker Lamp Assembly
Tip
• Release the tab from the inside of the fascia and push outward to replace the lamp assembly.
• Twist the bulb socket and pull inward to replace the bulb.
I have done this. You do not need to remove the wheelhouse completely.
