Halltech C6 Stinger SSM Installation Video
Old Apr 25, 2006 | 12:46 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Default Halltech C6 Stinger SSM Installation Video
We have limited bandwidth, so please download at night if you plan on purchasing a Halltech C6 Stinger SSM system. If the download seems very slow, try again later. The file is 80 Mb, so dial ups forget about it.
Here are instructions in pdf: http://www.corvettec5.com/Halltech_C...er_Install.pdf
Here are a list of our Distributors and Dealers:
http://www.corvettec5.com/store/?page=shop/dealers
Most of our dealers have specials for $369.00 going now through the end of April.
This intake system can be converted to an Indirect Cold Air Induction system with our optional ICAI. Intake air temps remain ambient with this optional system:
http://www.corvettec5.com/store/?pag...ae2675c9cb237d
Halltech can program your C6, eliminating countermeasures that reduce timing and add fuel to the tune of 10:1 air fuel ratios.
We have all the software and hardware GM dealers use to program your ECM, and start with the most recent calibration file for your C6, before we tune it with our "Off Board" programming.
Here's how:
http://www.corvettec5.com/store/?pag...f23c49ea9795be
Jim Hall
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
www.halltechsystems.com
Old Apr 25, 2006 | 12:56 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
I forgot to mention flow numbers. The stock C6 flows around 620 cfm to make 400 HP.
Check out this comparison flow bench chart done by Donaldson Company where they compare the stock C6 AIS to our C6 STinger SSM, vs. the new C6Z06 AIS.
The Halltech AIS nearly matches the Z06 AIS up to 700 cfm, which is more flow than the stock C6 utilizes.
In this graph and chart, less restriction is better. (Donaldson Company makes the Blackwing AIS, which is a direct competitor of Halltech Systems).
