Heads up Display
Old Apr 29, 2006 | 11:10 PM
SPROCKET's Avatar
SPROCKET
Default Heads up Display
Bought a used 05 C6 a few days ago and can't get the Heads Up Display to work. I have tried everything to get it to work. Any sugestions. THANKS
Old Apr 29, 2006 | 11:16 PM
C2Jeff's Avatar
C2Jeff
Forgive me for asking the obvious, but did you use the + button on the left side of the dash to brighten the display? Could be it's dimmed to the max. If not that, I got nuthin.
Old Apr 30, 2006 | 12:09 PM
Vette_DD's Avatar
Vette_DD
Have you checked the fuse for the HUD in the instrument panel fuse block on the passenger's side, under the instrument panel and under the toe-board? If you have the 2005 owner's manual, there's a diagram of the fuse block on page 5-88.
Old Apr 30, 2006 | 12:18 PM
Miaugi's Avatar
Miaugi
Also the up "^" and down arrows...could be it's not adjusted right for your eye level.
Old Apr 30, 2006 | 12:23 PM
glennhl's Avatar
glennhl
Or maybe it doesn't have HUD???? The base and middle models did not come with HUD.
Old Apr 30, 2006 | 12:24 PM
scrannel's Avatar
scrannel
Sorry for stupid-asking -- but does it have HUD? Not all do.
Old Apr 30, 2006 | 01:14 PM
VET4LES's Avatar
VET4LES
I wonder the same thing.
Old Apr 30, 2006 | 01:38 PM
Velvet16's Avatar
Velvet16
I had this issue 2 weeks ago when I just got my C6. It was the HUD vertical alignment. If you're tall (like I am) push the down arrow button (not the -) and hold it. Near the very bottom of the windshield the HUD will come into view. If you have a high sitting hight you can see the HUD when it's all the way at the bottom of it's vertical adjustment but you can easily drive it off the top and it will disapear.
Give it a try.
To Heads up Display
