2006 - Dead Battery Question
Old May 1, 2006 | 10:23 AM
71 Stingray's Avatar
71 Stingray
Default 2006 - Dead Battery Question
I travel a lot and the battery in my 2006 Convertible has been dead last two times that I came home after being gone for 2- to 4-weeks.
I know you had to park a 2005 in Reverse to prevent Accessory mode drain, however, I was told this wasn’t the case for a 2006. Any idea why the battery would die?
Also, during the installation of the “Factory Wind Screen” my battery did die and needed a quick jump (due to the constant up and down of the roof during installation). I did dive the car for about an hour after we started it. Then I did play the radio for about 2-hours when I got home to detail it.
All-in-all, none of this has ever killed a battery in any of my other Vettes. This time, it was so dead that a Jump Box couldn’t even turn it over and I had to get towed to the dealership for a replacement battery.
Any feedback or thoughts would be appreciated.
Regards,
Andrew
Old May 1, 2006 | 10:36 AM
timd38's Avatar
timd38
Regards,
Andrew
Everytime you run the battery dead, you shorten the life. Power tops are really hard on batteries if the engine isn't running.
Mercedes puts two batteries in the SL500, one for the engine and one for the rest of the car.
If it was my car, I would put a Yellow Top Optima group 35 in it. Yellow tops are made to be cylced and recharged.
Old May 1, 2006 | 11:10 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Sounds like you have a weak battery. Have them replace it under warranty (if it tests bad) and then start using a battery tender. Infrequent driving isn't good for battery life. I keep mine hooked up to a battery tender when I'm not using it. It charges only on demand.
Old May 1, 2006 | 01:24 PM
Mystical Musician's Avatar
Mystical Musician
As the future owner of an 06 C6 Manual, how often does DB syndrome occur on the 06 models, and what brand battery tender do people use since my vehicle will not be a daily driver? Is there a fix to this problem yet, or is this just a result of poor batteries?
Old May 1, 2006 | 01:51 PM
StanNH's Avatar
StanNH
I use a Priority Start on mine, which disconnects the battery if it drops below 11.9 volts. Dead batteries can happen with any brand of car ... the 2006 C6 with any transmission and the 2005's with automatics don't seem to have a serious issue though. The real "spike" is on the 2005 MN6 cars which have the "shift to reverse" shut down requirement and associated electronics. So, no, on the whole I don't think there have been an unusual amount of battery problems with any of the 2006 cars ... just a normal sprinkling of some bad batteries showing up.
Old May 1, 2006 | 02:44 PM
VET4LES's Avatar
VET4LES
If I ever have DBS I will install the PS.
Old May 1, 2006 | 02:56 PM
vetdude's Avatar
vetdude
The battery in my '06 C6Z was dead yesterday after sitting in the garage for two weeks. Car isn't driven that much - 580 miles since purchase the end of January. Jump started it and seems to be OK after taking it out for a couple of hours. Optima doesn't make a battery for the Z06 yet. She'll go on the Tender from now on.
Old May 1, 2006 | 09:25 PM
Hoonose's Avatar
Hoonose
http://forums.corvetteforum.com/poll...pollid=1500606
The unexplained dead or multiple dead battery rate is about 7-8% on this poll for '06 MN6. There are some Z06's in there, and also some '05 manuals mistakenly voted.
To 2006 - Dead Battery Question
