I keep reseting my Check engine light but it keeps cutting back on after about 100 miles or so.All I have done to the car is Borla Exhaust, LG long tubes, Fast Intake, Varram Cold air. Do you think it is my o2 sensor?
All you have done LOL. Did you get the car tuned after the installations. If so did they cut off the rear o2 sensors in the tune. I would take it back to tuners and tell them to double check.
why not pull the codes and see what it is, just in case it has nothing to do with what you have done.
I would pull the codes and find out what they were.
Were all these modifications done at the same time? If not which mod was installed just before the codes started? That will give you a clue but is not definitive. The best way is to find out what codes it is throwing.
