best cold air induction
Old May 16, 2006 | 01:45 AM
  #201
sallen619's Avatar
sallen619
Not installed yet. I sent it back to get the updated version. There are no 1/4 mile strips around here so I'll probably never know. I may do this... http://www.openroadracing.com/ . If I do, I'll be sure to post.
Old May 16, 2006 | 02:33 AM
  #202
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Heard about that. Sounds like a real good time.
Old May 16, 2006 | 05:13 AM
  #203
midnite902's Avatar
midnite902
Originally Posted by jimman
Last I checked 2 inches is less than 3, hard for you to grasp. If someone hydrolocs and I didn't warn them what would you say to that. There were more other than me that had this problem.
Please correct me if I am wrong. Your hydrolock occurred with the Halltach Tric?. That filter was of a completely different design than today's C6 bottom feeders, The filter in that unit sat so low the filter often had to be modified when the car was lowered. My LPE is over 12 inches off the ground enclosed in a cavity a couple of feet back from the nose. I have seen no reports of hydrolock with any of the filters that use this desgn (LPE, Callaway, etc.).
While hydrolock resulting from driving through puddles deep enough to cover the cavity and create a seal is a concern. Splashes, heavy rain, or traffic waves from small puddles are not.
I have driven my car in heavy rains here in Dallas and on the road over the winter without problems.
I think the new designs are much safer than your 'old' C5 Halltech but that is just my opinion.
Old May 16, 2006 | 07:08 AM
  #204
C5 Express's Avatar
C5 Express
Originally Posted by DSOM Z51
Woa
You are saying that ALL of his gain came from the tune and nothing from the Vararam?
I believe that he got "something" from the Vararam, but certainly not half of a second.
"...The first time 4/1/2005 2.048 60 ft.13.147 et 107.49 mph.4/1/2005 cartek fan switch 160 therm. 8/24/2005 cartek ECU Reprogram 2005 LS-2 minor tune A4. 8/26/2005 2.052 60 ft. 13.014 et 109.25 mph 60 ft. time...because tune might have been lost. when cartek checked they seen one new update so redid it for FREE. went back to track 10/27/2005 60 ft. 2.018 12.919 et 109.48 mph. temp 47 relative humidity 100 absolute baro 29.46 that's the best so far i think because of cold and miles. now vararam and spacer. 60 ft. 1.972 et 12.387 mph 113.36"
He had the Cartek tune before the Vararam and it got him from 13.014 to 12.91. Then, with the same tune, but this time with a Vararam, the car runs 12.38.
My contention was that the non stock tune by itself didn't offer much, everything else stock. The non stock Vararam airbox, plus the non stock tune gave the 12.38.
But that the results of the Vararam in the bone stock car were unknown.
Please explain in further detail why you believe that ALL of the gain came from the tune?
I'm just throwing that out for discussion.
A tune is not an instant change for the fuel trims. It can take a long time for them to stabilize. That also affects timing, showing up as knock retard. After they stabilize, you have to scan again and normally adjust some more. It's rare to get them set perfect on the first adjustment.
If he was running 13's there was something very wrong with that car. Also if his best run is a 12.48 that is not his average. This summer he'll see 12.8 consistent.
My stock C5 runs 12.65 for a best. Usually 12.8/12.9 Whoops, I said stock. It does have a Blackwing over a cutout in the shroud, 3:42 and my tune.
Old May 16, 2006 | 08:09 AM
  #205
dennis50nj's Avatar
dennis50nj
the .03 difference in consistency will win many races you can change your dial each round an dial in 1/10 slower but it don't mean any thing if you cant pull a good light. most 05 c6 a4new of my weight ran 13.s and the car does run 12.06 now and probably 11s next time down and you are right it takes 200 miles to see final gains that's why you cant do on of same day testing
Old May 16, 2006 | 09:23 AM
  #206
C5 Express's Avatar
C5 Express
You can do it same day as testing. I am not going to post how but you can PM me if interested.
My average lights for the last year is .028. I've had several .000 this past year. That helps me win a few but my car HAS to run a .01 or less variable or I won't last long.
I also have never seen a C6 run 13's. I need to start paying closer attention. Stock C5's run 13.1/13.2 right out of the factory. How can a C6 be that slow with more ponies?
Old May 16, 2006 | 10:01 AM
  #207
jimman's Avatar
jimman
Your correct it was the tric and is lower, also with a different nose design. I also ran it nearly 45,000 miles before it happened to me. So taking all that in I still would have concern with having a vacuum facing the ground. Next time it rains just observe other cars at different speeds and pay attention to the wake the front wheel cause, that’s what got me and the other guys, a couple of which where in Texas.
Old May 16, 2006 | 10:38 AM
  #208
LS1LT1's Avatar
LS1LT1
I've seen it, especially if they were brand new and running in less than stellar air quality, torque management plays a role as well.
Old May 16, 2006 | 11:14 AM
  #209
C5 Express's Avatar
C5 Express
I'm just surprised. I think you run at E-Town and know a lot of the same guys I do and they run mid 12's. I thought they were stock, maybe not.
Old May 16, 2006 | 02:51 PM
  #210
dennis50nj's Avatar
dennis50nj
i have taken the stock air bridge off and seen a 1/10 slower took filters out 1/10 slower even with rr slower till computer relearns at first extra air more fuel retards timing even if you tune right their it will change that's why dyno numbers are different each run. and if you have a lot of rounds to run clean ups on track sun weather changes from day to night as you said da can change quickly .01 seems impossible i have raced since 68 a lot of bracket racing won a lot of rounds won a Winston cup championship in heavy eliminator in 81.always changed dial some times every round 400 plus cars in the class that day. good light good brakes good win. checkout c6 times most in 13s most don't post until better and torque management is what kills them 2.10 and slower 60 ft no tire spin and believe me their is no way to remove on a4 or a6 if you no away can guarantee way better 60 ft you will be rich
Old May 16, 2006 | 03:32 PM
  #211
LS1LT1's Avatar
LS1LT1
I usually run at Atco (sometimes E-town) but I'm at E-town a lot to spectate for the Corvette Challenge and F-body events...yes a lot of them are hitting 12s now after learning their cars better but few if any are still pure stock as far as I know.
Old May 16, 2006 | 03:45 PM
  #212
dennis50nj's Avatar
dennis50nj
DSOMZ51 sorry for being such an ***. now that i thought about it i believe you are right the tune probably helped a lot. because so much time had passed between runs the shift points higher rpms timing and fuel had to play a big role i never listen to the wisdom of experience i always have to hear a lot think then make my own decision
Old May 16, 2006 | 05:13 PM
  #213
robotpedlr's Avatar
robotpedlr
Well I have read CAI posts until I was dizzy, trying to figure out which one was right. Seems that most people like the performance of the Vararam but not the build quality (fit, finish, install, etc)...but now it looks like a new version with all that corrected is coming out. I am going to order that unit and give it a shot.
I will report my findings on this board when I get it installed. I will also post info on the build quality, and how it compares to the older version we have read about.... wish me luck!
Old May 16, 2006 | 05:22 PM
  #214
Joe_G's Avatar
Joe_G
St. Jude Donor '08
You and me both! Please post when the new ones are shipping, I'm going to place an order also. Thanks!
Old May 16, 2006 | 05:56 PM
  #215
'06 Quicksilver Z06
No prob. I wasn't very nice for the whole discussion either so I apologize as well.
Old May 16, 2006 | 08:02 PM
  #216
C5 Express's Avatar
C5 Express
No, I didn't mean it that way. I mean I have to have the car run under.01 from what I dial. I have matched my weather station to the car and depend on it for my predictions.
I've been told that the Fast computer will automatically compensate for the weather and the car will run the same number regardless of the weather. I have no idea how much it varies. And they are very expensive.
Old May 16, 2006 | 11:12 PM
  #217
dennis50nj's Avatar
dennis50nj
