best cold air induction
Old May 5, 2006 | 08:24 PM
bobartstar's Avatar
bobartstar
Default best cold air induction
should be getting new artic white on black in a few weeks wondering whats the opion on best cold air induction and exhaust would like to order them now, liked the snake charmers hp claims but read alot of bad reviews, thanks
Old May 5, 2006 | 10:26 PM
dennis50nj's Avatar
dennis50nj
snake charmer i dont see none of these problems its the best imho kooks long tube
Old May 5, 2006 | 10:44 PM
Drumhawk's Avatar
Drumhawk
What's the bad on the snake charmer? I assume that maybe it doesn't quite produce the numbers it claims or are there water issues or any other problems with it?
Old May 5, 2006 | 11:29 PM
dennis50nj's Avatar
dennis50nj
i have had no water problems. i have stated this many times 12.91 before 12.38 after test done before and after similar temps and humidity
Old May 5, 2006 | 11:39 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I'm scheduling my C6 for the Vararam Snake Charmer, LG Pro Long Tube headers and a Corsa Sport exhaust. I considered the LPE cold air induction (as a trip to LPE is next on my 'to do' list) but I have friends running the Snake Charmer and they swear by it.
Old May 6, 2006 | 01:32 AM
Stingray23's Avatar
Stingray23
Thats a huge difference in ET with just an intake
Old May 6, 2006 | 03:51 AM
kca009's Avatar
kca009
From what I've read on the forum, it looks like a piece of crap. Doesn't fit right, and has poor directions.
Old May 6, 2006 | 05:22 AM
LS1LT1's Avatar
LS1LT1
Hey, if it actually provides substantial gains over other so called better looking cold air kits then that's ok.
This is the tech/performance section right, I think the waxer's, err I mean appearance/detailing section is down there somewhere?
Old May 6, 2006 | 06:29 AM
Miaugi's Avatar
Miaugi
Old May 6, 2006 | 04:32 PM
glennhl's Avatar
glennhl
I love this response! I've had Fbodies up until now. My observations of the differences between Camaro owners and Vette owners:
1) You will be a hero with Fbody owners (LS1Tech.com) if you can tell them what is the biggest cam you can run without having to flycut your pistons.
2) You will be a hero with the Corvette owners (Corvetteforum.com) if you can tell them what is the best wax for their car.
Old May 6, 2006 | 04:46 PM
rickyc6's Avatar
rickyc6
7th Gear
Default thanks!
thanks for the long list of postings on cold air induction i missed, and you did a great job with the packers as well!
Old May 6, 2006 | 04:51 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Calloway
Old May 6, 2006 | 04:55 PM
glennhl's Avatar
glennhl
I am running the K&N aircharger, very much like the Halltech. It comes down to what you want, a bottom breather or not. The bottom breathers are the Honker, LPE, Vararam, a few others. The top breathers are the Halltech, K&N, a few others.
The bottom breathers will make more power. The top breathers are safer from a hydrolock.
Old May 6, 2006 | 07:41 PM
timd38's Avatar
timd38
I did K&N.
Old May 6, 2006 | 08:20 PM
greentank's Avatar
greentank
From what I've heard, hydrolock is only a problem with manual transmissions. True?
Old May 6, 2006 | 08:24 PM
glennhl's Avatar
glennhl
No, tranny doesn't matter. If you get a lot of water into a rotating engine it will lock up. You may not crash if you have an auto, but the engine is still going to be damaged. Plus, it's not even that dangerous with a manual, you just have to push the clutch in.
Once you fill a cylinder with water, the next compression stroke the piston tries to compress an incompressible liquid and it results in bent rods or broken cylinder walls.
Old May 6, 2006 | 08:30 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Transmission has nothing to do with hydrolock.
To best cold air induction
Old May 6, 2006 | 09:44 PM
Drumhawk's Avatar
Drumhawk
I'd like to hear from anybody who's had problems with the Vararam ie: water in the engine. I just had one delivered and I'm having 2nd thoughts about installing it now.
Old May 6, 2006 | 09:55 PM
glennhl's Avatar
glennhl
I' ve only read of one hydrolock on this website and I think the guy drove it into a pretty large puddle. However, when it rains here it pours and I would be a nervous wreck waiting for my engine to hydrolock. I can't imagine that GM will cover any damage even under warranty!
Old May 6, 2006 | 10:15 PM
Drumhawk's Avatar
Drumhawk
I'm nervous already before the install as I live in Vancouver where we get alot of rain, not that this is my daily driver but getting caught in the rain will eventually happen, somone said there are no water issues with the vararam but after looking at it in person I wonder if moisture will get past the filter?
