I'm scheduling my C6 for the Vararam Snake Charmer, LG Pro Long Tube headers and a Corsa Sport exhaust. I considered the LPE cold air induction (as a trip to LPE is next on my 'to do' list) but I have friends running the Snake Charmer and they swear by it.
I have nearly identical mods ordered. I am trying to get the 3" Corsa system for the C6. It is supposed to out this month.
I'm nervous already before the install as I live in Vancouver where we get alot of rain, not that this is my daily driver but getting caught in the rain will eventually happen, somone said there are no water issues with the vararam but after looking at it in person I wonder if moisture will get past the filter?
I had a Haltech TRIC cold air intake on my C5. There were people who handgrenaded their LS1's w/ this intake. I drove mine through several torrential downpours and never had a problem. It's standing water that will get you. That can be avoided 99% of the time. Not being a daily driver helps. The cold air does make more HP.
By the same token, I handgrenaded the motor in my 98 Lumina and it had the OEM intake. Fortunately, it was a company car (may she rest in peace) and I did drive it through some pretty deep water. Common sense is more of a factor than the style of intake.
ever drink a soda with a couple holes in the straw.
if it bothers you that much drill a couple holes up higher in the housing before filter. put plugs in them. take out when you want to drive in deep water
I love this response! I've had Fbodies up until now. My observations of the differences between Camaro owners and Vette owners:
1) You will be a hero with Fbody owners (LS1Tech.com) if you can tell them what is the biggest cam you can run without having to flycut your pistons.
2) You will be a hero with the Corvette owners (Corvetteforum.com) if you can tell them what is the best wax for their car.
Truer words were never spoken.
Re the Vararam, I have one on my C5, and it works as advertised. Unless you try to ford rivers, hydrolock is not a problem. However, the fit, finish, and install instructions were substandard, and it is difficult to seal the air filter correctly. I intend to try the Honker for my C6.
If you plan on being a U-boat commander with your vette then hydrolock may be a problem. But if you avoid water as much as you can and don't drive into a lake you'll be fine. That's how I think Ed at LPE put it to me lol.
From: Prepare yourself, for a pride obliterating bich smack. Fairfax, VA
St. Jude Donor '06-'07-'08
SEC > BCS 4 St. Judes '09
Originally Posted by SpinMonster
HAHA! True but you forgot the average response to a tech question on the mod boards here: GM designed it that way so don't mod the car.
you gotta give those poor guys credit...GM did a fine job with the 6 and it really doesnt NEED anything. so if that's what it takes for them to rationalize not having to fight the wifey for mod funds and sleep on the couch everytime UPS shows up with a new big box...then that's fine.
but for me...its MOD MOD MOD MOD
oh yeah...Callaway Honker. LPE is comparable, so i've heard. Cant go wrong with either of these two.
i am at 389 rwhp with my honker, lgs, bullets, and LS2 Edit.
I bolted on my Snake Charmer two weeks ago. The quality of materials is poor, and I have had the provided rubber connector slip off the end of the intake twice because the end of the intake isn't quite long enough, nor does it have a lip on the end to hold the connector securely in place by the screw clamp. Moreover, it crimps if you torque the screw clamp down too tight. I have had to straighten mine with a pair of pliers. Installation is relatively easy, but the template for cutting the radiator shroud is poor, and the recommended cut-out location is way off (much too high). Once you bolt the entire unit into place, the top half which contains the filter separates from the bottom half of the unit exposing a little bit of the filter. You can cut the radiator shroud with a box cutter without having to remove it from the car. All of the above having been said however, I have really felt an increase in throttle response and acceleration seems to be much smoother. If Vararam made this piece of better materials, there would be no alternative intake that could touch it.
From a performance point of view, VaraRam is the best. However, from a fit and finish point of view, VaraRam is the worst.
Honestly, I don't know if any of the CAI set ups are that much better than stock. Unlike the C5, GM did a pretty good job of designing the stock air box. Frankly, I find it hard to justify the cost of an aftermarket CAI.
numbers talk man. like i said in a previous post...the CAIs have been adding an additional 15-20rwhp to header packages with tuning. as a stand alone mod, no intake is going to do much of anything. but as part of an overall mod plan, its utility increases significantly.
I can't recall if they said 'most' or 'all' but you can ask them directly as they're forum sponsers. I believe it's Reese from MTI that posts here from time to time. It would be helpful to know the exact models tested, not sure if that would get too political amongst sponsers/vendors or not though...
Edit - Actually it's Steve that posted here. I sent him a PM to see if they cared to comment on the thread. Not sure how often they stop by.
Mayonayze..........I can agree with your statement. The stock airbox is sufficient for the stock motor. Once you start adding mods, however, then a you'll see the benefits of a CAI.
