LS-2 engine question
Old May 7, 2006 | 03:46 PM
Velocity Steve's Avatar
Velocity Steve
Default LS-2 engine question
Chevy advertises that the LS-7 has 6 bolt main bearings but I've not seen any mention of that spec for the LS-2. Does anyone know how many bolts are used to secure the main bearing caps on the LS-2?
Old May 7, 2006 | 04:05 PM
DrivnXcitment's Avatar
DrivnXcitment
Don't quote me on this one, but if I recall correctly, the LS2 has 4 bolt mains.
Old May 7, 2006 | 04:25 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Well don't quote me either, but I believe the LS1, LS6, and LS2 all have 6 bolt (cross bolted) mains as well. There are 4 bolts in the bottom of each main bearing cap similar to 4 bolt mains and 2 horizontal bolts (1 on each side) i.e. "cross bolted mains" .
Old May 7, 2006 | 04:30 PM
supersporttruck's Avatar
supersporttruck
Old May 7, 2006 | 04:38 PM
Velocity Steve
Thanks to those who replied. I assumed they'd be 4 bolt mains because of the way Chevy bragged on the 6 bolt mains in the LS-7 as if it were unique.
Old May 7, 2006 | 07:06 PM
timd38's Avatar
timd38
I found this.........
At a Glance: 2005 LS2
Engine type OHV V-8; aluminum block and heads; 6-bolt main bearings Displacement 364 cu in / 6.0 liter Bore 4.00 in / 101.6 mm Stroke 3.62 in / 92 mm Compression ratio 10.9:1 Fuel delivery Returnless, sequential port fuel injection Redline 6500 rpm Horsepower 400 @ 5200 rpm Torque (lb. ft.) 395 @ 4000 rpm
Old May 8, 2006 | 02:28 AM
LS1LT1's Avatar
LS1LT1
I think that's some preproduction/early info (or maybe it's the GTO's specs?), the torque rating for the C6 is 400 now.
Old May 8, 2006 | 07:58 PM
calemasters's Avatar
calemasters
The LS2 (VIN 2) crankshaft bearing caps each have 4 vertical M10 and 2 horizontal M8 mounting bolts.
Old May 11, 2006 | 04:36 PM
Velocity Steve
Wow! 6 bolt mains. Thanks to all who answered.
To LS-2 engine question
