The Vararam? whats that? a cold air induction? i heard of it just not familiar?
Tommy i ran my 05c6z51a4 several times made some changes, every change i made i always compared weather humidity temperature, your car learns some changes. takes time so you cant due same day back to back comparisons. like take air bridge off filters out will slow you down till computer learns change, about 200 miles. the short story is the vara ram and spacer made the biggest improvement to my car. same temp within 2 degrees same humidity 12.91 to 12.38 after vara ram and spacer. that's more than a half a second on car similar to yours
If it detects your car getting slightly sideways it steps in and cuts power.
Here are your options:
as is = TC ON + AH ON = Slowest
1 press of the button = TC OFF + AH ON = Quicker
2 presses of the button = Competitive Driving Mode = TC OFF + AH ON, but at a reduced capacity = Even Quicker
Hold Button in for 5-10 seconds = TC OFF/AH OFF = You are on your own = FASTEST = NOT FOR THE STREET where the added safety of any of the other choices is smart
