Drag Radials - Help With Selection
On the C6, the average is about 1.8 (Before tuning)
You need to launch hard or you will bog
For some reason, the C6 just does not launch like the C5.
So please tell me the launch rpms you have been using with the C6 on MT ET Street (bias ply). Also have you experienced clutch pedal issues with those tires.
TIA,
Ranger
I only have 4 passes on the C6 with the ET Streets, I'm still experimenting.
With a stock ECU (e.g. no tuning), a soft, sticky tire will produce worse 60' and ETs than a DR that will allow a bit of spin on the launch.
The downside of tuning out TM is the warranty concern. If you tune it and the car breaks the tranny or rear, a Chevy district/zone rep can see the tuning via Tech-II and deny warranty coverage.
So I plan to leave my ECU stock and try to find a technique for driving around TM.
Meanwhile for C6 owners with stock ECUs, I suspect your 60' will be better with DRs and carefully regulated (1) launch rpm and (2) clutch release that allows for some (3'-10') wheel spin. This approach will likely reduce the TM impact.
TM is there to reduce Chevy's exposure to warranty loses. If you edit TM out, you accept the risk of potential denial of claims involving the drive train. Many owners are willing to accept such risks in pursuit of fast times. Others prefer to remain stock and adjust their driving techniques instead.
Ranger
Steve.
Knowing the wheel/tires is a start. How about the rest?
TIA,
Ranger
Steve.
I wish I would have had the real scoop.
Good example of don't believe everything you read on here.
TIA,
Ranger
Ranger
Trying to find out what seems to work. That take cooperation from members.
Anyone?
Ranger
Looks like those running DRs aren't motivated to share what they've learned.
A post like this on the C5Z06 board would draw a lot of members' experiences and support for your decision.
Ranger
I am but a novice yet, but a little trial and error never hurt. I mainly posted the question b/c I've been to the track twice, for the Corvette Challenges, and found my main problem was with hooking up. Additionally, I do need to work on my RTs.
Steve.
OK, Beer Re-Loaded, and the M/T ET Streets are 275/40/17. My apologies Ranger, and everyone else for not posting this sooner, however, I have been a little busy at work. Today, on my only day off in awhile, I have been rolling around in the garage floor, installing a DIY CAI thank's to David Farmer's post on this thing ! Almost done, just need a heat gun, and a little tweaking !
I've considered picking up some used C5 Z06 wheels, as they might be the right size. I understand that I can't get drag radials on the wheels that are on the car, as they are 19's in back.
1. What tires do you recommend. Pease be specific with regards to size & width, brand, etc.
2. With which wheels? Again, size please.
3. How do you guys feel is the best way to release the clutch? What rpms? How do you feel that this impacts on tire selection and what role does TM play / ECU reprogramming play here?
If you can, please list your average 60' times, 1/4 times, and list what you're running in terms of performance mods, tuning change vs. stock, and wheel / tire package. Thanks!
Thank you. Hopefully, this thread can generate a fairly comprehensive list of wheel / tire / mod packages that can help me and others new to drag racing choose the best package for their needs.
.I was sorely disappointed with my results. Best 60 was 1.964, most around 2.01. Best time 12.97 at 110. Most around 13.0-13.2. I could run this with my C5 with only Blackwing and Borla and it had only 300RWHP before H/C.
Ranger, thanks to reading your threads I had gotten my 60's on my C5 down to 1.6-1.8 pretty consistently following your method and was running high 11's (it had H/C). I'm no pro for sure but I'm not a beginner either and I couldn't get this car to run hard.
I just cannot keep from bogging at the line - launch hard, launch easy, same thing. Sometimes I got a little wheelspin then bog depending upon launch RPM. And when I shift it feels like the car is again bogging. I suppose this is the torque management people talk about. Even my wife in the stands asked why it seemed to die out when I shifted (I'm surprised she could hear this friggin quiet thing). This car just feels slow to me, I swear I can read a book while waiting to shift to 4th. I gotta start modding!!!
I have been reading threads on this torque management, it seems some folks believe in it, and some don't. What's the real deal?
All things equal, brands aside, do you think I'd be better off with 17" than 18"? I've heard it allows a little more forgiveness in the sidewall for twisting, and may be easier on the car. I believe both will fit, as both Joe G and CYA-VETT did have 17's on the back of his Z51 C6 last week.
Also, you mentioned you think 315's would be a good width. I know we haven't gotten the consensus we'd like from this thread, but if you were to pick out DR's for a stock C6, would you still go with 315s on 18" wheels as you stated in the other thread?
The ET Streets' sidewalls flex. They only make a 17 inch size right now. They are taller than the 17 inch DR but more forgiving and stickier.
I just cannot keep from bogging at the line - launch hard, launch easy, same thing. Sometimes I got a little wheelspin then bog depending upon launch RPM. And when I shift it feels like the car is again bogging. I suppose this is the torque management people talk about....I have been reading threads on this torque management, it seems some folks believe in it, and some don't. What's the real deal?
With 500+ passes in two C5Zs and now 21 in the C6Z, I'd hope folks would give me credit for understanding with a normal launch feels like.
And your sense coincides with mine. TM is pulling power if the rear wheels don't spin a bit. Simple as that.
I've run 1.78 on the stock tires but my big sticky DRs won't produce better than 1.73. Pretty revealing. Raise the launch rpm by 1000 and shave only .05 off the 60' and have a slower 330'. That's the TM toll.
So you are correct. TM is a ****.
I'm doing experiments to find a launch technique that will evade TM. No luck so far. But then, I make two passes and get told to park it for violating the 11.50 lower limit.
Looking toward track rentals.Ranger
Wheels/tires that work on the C5Z:
C5Z06 fronts 17x9.5 wearing ET Street Radial 275.45.17 22-26 psi
C5Z06 fronts 17x9.5 wearing BFG DR 315.35.17 DR 18-20 psi
C5Z06 rears 17x9.5 wearing BFG DR 315.30.18 DR 18-20 psi
I'd suggest raising the psi by a couple and being a bit more aggressive with the throttle once the clutch is out. The goal is to get some wheel spin. This may serve to reduce the TM toll. That's the theory I'm pursuing.
Ranger
People drive on MT Drag Radials like I have on the street all the time. I'm a bit skittish to do so on my every day drive but people do it. Just gotta be really careful in the rain. Standing puddles are a no no - just ask Johnsea06 at the next event!
Search for his user name and look at his avatar... that was from his in car camera at homestead running R tires through a standing puddle!
What are you doing posting at 9:30 on Sunday night. Don't you know the Sopranos is on???
I'm thinking you're tires are probably perfect for me. It's just that I'm a little scary obsessive when it comes to purchases like this. What did you say you're trading up to and why?
Craig
