Drag Radials - Help With Selection
I've considered picking up some used C5 Z06 wheels, as they might be the right size. I understand that I can't get drag radials on the wheels that are on the car, as they are 19's in back.
1. What tires do you recommend. Pease be specific with regards to size & width, brand, etc.
2. With which wheels? Again, size please.
3. How do you guys feel is the best way to release the clutch? What rpms? How do you feel that this impacts on tire selection and what role does TM play / ECU reprogramming play here?
If you can, please list your average 60' times, 1/4 times, and list what you're running in terms of performance mods, tuning change vs. stock, and wheel / tire package. Thanks!
Thank you. Hopefully, this thread can generate a fairly comprehensive list of wheel / tire / mod packages that can help me and others new to drag racing choose the best package for their needs.
My wheels have been widened and are now at the chrome shop. Post on that thread so you can keep up if you are interested.
I plan to run either 295 or 315 BFG DR's.
I run C5 Z06 front rims with 17 inch ET Streets
If you are considering bolting your tires on for track use, get the ET Streets, not the Drag Radials. Swapping back and forth defeats their purpose. Either keep them one all season, or get tire meant for the drag strip. By the way, BFG Drag Radials have about a 5,000 mile life.
As far as launching, you have a stock car, if you use ET Streets and do a decent burnout, you can launch as hard as you want without any wheel spin.
You can see in my avatar how hard they hook and see below how they look on the car.
As you know, I don't have the Z51 package...but I stayed at a Holiday Inn Express last night
Does anyone know that they fit over the Z51 brakes?
It is getting a little expensive though.
Great pics! I'm still talking to her, I think there might be a little movement my way. BTW, just order the Raptor shift lite so if I ever do get to take it down the track I will know when to shift before hitting the redline.
You are recommending MT ET Streets (bias ply) over the MT Street Radial? And those get better tire life on the street than BFG DRs?
Ranger
Ranger
I was trying to clarify that bolting on drag Radials at the track is not really ideal since you can use them for every day driving, just keep them on all teh time. And if he had that plan in mind get the ET Streets (bias ply). Since you should basically ONLY use them at the track and since bolting on the DR's required an extra set of rims anyway.
In short, if you aren't leaving them on ALL the time, I think the ET Streets make more sense.
ET Streets are good for about 100-130 passes. I can, but rarely do drive around with them on, but I have driven 150 miles on them to the track.
I used to use the BFG Drag Radials for all of my driving and averaged 5,000 miles. Since the ET Streets are cheaper, grip better and are a bit easier on the drivetrain (due to sidewall flex), I use them exclusively now.
Sorry for the confusion.
This logic may not pertain to your Z06 since there is no 18 inch ET Street yet and a 17 inch rim may not fit your car.
Dave
I personally like the Nitto's, I run them on some spare C6 copy C5 sized front wheels, stock 17 inch C5 size. I do not have Z51 though. The ET Streets need some getting used to, they get squirlly on the top end, dont take corners at all in town driving.I ran them in a 16 inch size on my 89 Turbo TA. They didnt last long on the street either. I get 10k miles on my Nitto's and they hook up better (In my opinion, please no tire war) I personally just like them better than two other brands of DR I have bought and worn out, also better than two cars that I ran ET Streets on also until worn out. In my opinion they handle pretty good for street cornering and in light rain too.
I personally like the Nitto's, I run them on some spare C6 copy C5 sized front wheels, stock 17 inch C5 size. I do not have Z51 though. The ET Streets need some getting used to, they get squirlly on the top end, dont take corners at all in town driving.I ran them in a 16 inch size on my 89 Turbo TA. They didnt last long on the street either. I get 10k miles on my Nitto's and they hook up better (In my opinion, please no tire war) I personally just like them better than two other brands of DR I have bought and worn out, also better than two cars that I ran ET Streets on also until worn out. In my opinion they handle pretty good for street cornering and in light rain too.So basically, you do not need bias ply's up front, recommended maybe, but need, certantly not.
I've been using this combo for years, the rims I am using are left over from my old car.
This combo has proven to be much cheaper for me than DR's since you drive them (DR's) around all year, thus you have to replace more often. Plus ET Streets hook better.
(1) Is your ECU tuned?
(2) Is your clutch stock?
(3) What is your average and your best 60' wearing ET Street bias-ply?
(4) With that tire, what is the general range of launch rpm you are using?
(5) How many passes are you expecting to get from the clutch?
TIA,
Ranger
I ran the same combo on my C5 Z06 (with heads/cam) and could pull any 60 I wanted from 1.6-1.8. I've seen lower than 1.6's on them from other guys. (Robz) (Dr.Ron) I averaged 1.8's since I had no roll cage and wanted to stick around
For me, one of the biggest advantages of these tires is consistency. Both for launching and shifting, there is no wheel spin during shifting.
Now, I cannot drive like you, so it may be a smaller factor for you but I would think it might help your ET's. On the down side, they are taller than DR's so that may hurt you too.
For some reason, the C6 just does not launch like the C5.
