top delamination concern
BUT... I read a post yesterday, where someone claims that he lost his top while driving and it was due to the "delamination" issue. I have an appointment next week to get mine looked at before I go on a trip over Memorial weekend.
The idea of an "inspection" might sound like a prudent thing to do, but assuming the GM dealer follows the dictates of the Bulletin, if you appear at the dealership with a painted top, you'll get the foam treatment or a new top. There are no other options available. "Whenever a vehicle subject to this program...is in your dealership for service prior to March 31, 2007, you must take the steps necessary to be sure the program correction has been made before...releasing the vehicle."
The 12-page Bulletin containing instructions on injecting the 2-part foam (which sets up in 15 seconds) into a top which passes inspection lead me to conclude that the technician doing the work better be pretty clever, and experienced to avoid messing up your baby's lid. "It is difficult to clean the foam off of visible surfaces."
If a feeler gage can be inserted into any of the 6 areas shown on page 3 of the Bulletin, the top must be replaced and of course, repainted. Hobson's choice it seems.
They gave me a loaner while they worked on my car and the whole deal was totally painless. If you've gotten the recall, my suggestion would be to just have it done.
Thanks,
Gene
Thanks,
Gene
"They won't replace it with the lexan top, however, since that top is priced twice as much as the painted top."
The cost is about the same, I believe, since it is essentially the same resin used for both clear and painted tops, but what they can charge is higher, since one is percieved as more valuable.
Hmmm,,, ran across this patent, thought someone here might be interested... I guess GM missed it
, note the bold I added, below:United States Patent 6887573
BACKGROUND OF THE INVENTION
Transparent blends of polycarbonate and polyesters have attractive properties like toughness and chemical resistance. Also, UV resistance is improved over that of polycarbonate by itself. U.S. Pat. No. 5,942,585 to Scott et al relates to clear blends of polycarbonates and polyesters where the polyester comprises a dicarboxylic acid component based on 1,4-cyclohexanedicarboxylic acid units and a glycol component comprising 2,2,4,4-tetramethyl-1,3-cyclobutanediol units. U.S. Pat. No. 6,136,441 to MacGregor et al relates to substrates with an adherent cycloaliphatic layer. References disclosing polycarbonate polyester blends and their transparent properties include U.S. Pat. No. 4,879,355 and GB Patent Application No. 1,559,230A.
Durable, glossy fascia associated with articles such as automobiles, luggage, appliances, and other durable articles made from plastics increase both the aesthetic appeal and the utility of these articles. Clear coatings on exterior of articles are useful for their scratch and abrasion resistance, as well as toughness and aesthetic appeal. A continued problem in the use of coatings is bonding the outer layer to the substrate layer.
. I have read the new tops have the same problem.
. I have read the new tops have the same problem.. Mine came off last weekend and the new tops are on back order. The dealer does not know when they are going to get any in. I called the parts dept. on Friday and the clear top is $1600.00. Hell I would be happy to pay the difference if they would work with me on it. By the time they pay for the roof and have the body shop paint it then spend $50 a day for 3 weeks for this god forsaken Yukon they gave me to drive they would be way ahead.
. There is 1 poster on here who is on their 3rd top.
The tech said that there was nothing wrong with mine, but he is still required to inject the foam for precaution.
Looks like a new top is the next step.
