Drone
Old May 12, 2006 | 12:59 AM
06corvette's Avatar
06corvette
Default Drone
When talking about a cat-back I read the word (drone)
and I still don't anderestand what does it mean?
can anyone explain it to me
Old May 12, 2006 | 01:05 AM
midnite902's Avatar
midnite902
It is a low hum thaat happens at low rpm with some cat back systems. It is not the sound as much as the harmonic vibrations that bothers people. It has made some sell their cat back systems at a loss.
Research well before you buy
Old May 12, 2006 | 04:45 AM
C2Jeff's Avatar
C2Jeff
My bone stock C6 vert now has drone at idle and I don't like it one bit.
Old May 12, 2006 | 06:12 AM
Turbooo2u's Avatar
Turbooo2u
Old May 12, 2006 | 09:16 AM
SS MPSTR's Avatar
SS MPSTR
It is more of a resonating sound within the car and annoys most people. My 99 has a drone at a certain RPM with the Borla Stingers...I will make sure I don't have it when choosing a cat-back for my C6.
Old May 12, 2006 | 09:37 AM
musclecar6's Avatar
musclecar6
Corsa exhausts are the only ones that have no drone as reported by a whole bunch of people in their opinion. I have a corsa pace car exhaust on my 99 C-5 that has no drone. After reading numerous reports on here & elsewhere about problems with drone on other brands I wouldn't even consider anything but Corsa when I change the exhaust on my C-6 which I will be doing soon. Some people complain that although the Corsa doesn't have any drone It has more of an exotic or "euro" sound rather than a "musclecar" sound. I really like the Corsa sound & for a daily driver that I use my C-6 for the last thing I want is an exhaust that I have to "workaround" the infamous drone supposedly in the 1500 to 2000 rpm range by changing gears. Ridiculous. Just my humble opinion.
Old May 12, 2006 | 09:56 AM
C2Jeff's Avatar
C2Jeff
Originally Posted by Turbooo2u
It's something that just started recently and I can't explain it. At idle it sounds almost like some ricer has his bass turned up loud nearby. Well, maybe not that annoying and not that vibrating but still noticeable and a little annoying. I just hope it doesn't get worse.
Old May 12, 2006 | 09:57 AM
BLKVETTEVERTZ51's Avatar
BLKVETTEVERTZ51
If you let your grandmother drive it you will hear the drone. If you drive the car the way it was meant to be driven drone will not be an issue. If the 1st to 4th happens alot for you then do not get the Borlas. I have the Borla Stingers and I love the sound.
Old May 12, 2006 | 02:34 PM
Vettegasm's Avatar
Vettegasm
Cruising
Most people say installing the exhaust manufacturers xpipe when going to a cat back all but eliminates the drone.
Old May 12, 2006 | 09:37 PM
yell03's Avatar
yell03
DRONE is a DEEP BASSY HUM that makes you feel like your head is going to explode.
My B&B Bullets with my A4 auto tranny produced HORRIBLE DRONE when the windows and top were up.
It was almost unbearable, but definitely not pleasurable.
I swapped them for the Magnaflow #15884 catback and I am pleased to report there is NO Drone.
The Magnaflows do not have as MEAN a sound as the Bullets, but at least they are tolerable to drive in all situations.
Hope this helps,
Howard
Old May 13, 2006 | 11:51 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
"Drone" is the annoying sound from your exhaust that typically occurs when you're cruising along on the highway at 1800-2000 rpm & the exhaust note should be relatively quiet (versus when you're accelerating or decelerating). Tends to be very annoying on road trips...like the sound of a dentist's drill being transmitted thru your skull Not fun on a long trip. I just put Corsa Sports on my Z51/MN6 after much research on the Forum to find a good solution to this potential problem & I must say, the Sports are absolutely as advertised. Great sound on acceleration...very mellow on cruise...and no drone!
Old May 13, 2006 | 12:13 PM
GooseyGoose's Avatar
GooseyGoose
B&B Bullets with PRT.
Awesome Sound, A little drone but disapears when you step on the gas which I do alot.
Sounds like a American Muscle Car should sound like...
Old May 13, 2006 | 05:42 PM
catbert's Avatar
catbert
So far, any catback that measurably reduces back pressure ends up with some drone at some rpm. Corsa Touring has little or no drone, but isn't much different than a stock system in sound or power - IMHO.
Old May 13, 2006 | 05:58 PM
06corvette's Avatar
06corvette
thanx guys for helping
I think most of people have this sound
I think I can live with it
I am going to buy stinger borla they sound great
Old May 15, 2006 | 03:19 PM
Low Rider's Avatar
Low Rider
Don't buy B&B if your worried about drone......only buy them if you want the best sound going Mine sounds like a street driven Pro-Stocker and thats just the way I want it.....
Old May 15, 2006 | 05:27 PM
GooseyGoose
I have the Bullets with PRT and am removing the PRT tomorrow.
Do you have the PRT or just run them straight? do you have a x-pipe or just the Bullets?
To Drone
