235 / 40 / 18 on front?
Old May 18, 2006 | 12:02 AM
C5nNC's Avatar
C5nNC
Default 235 / 40 / 18 on front?
Finally there's a race tire out for C6, but only has a front directional tire in 235/40. About 1/2" difference in height and little more in width. Do you think it will make a huge difference?
Old May 18, 2006 | 11:38 AM
MKS's Avatar
MKS
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
245/40-18 3.9in 12.9in 25.7in 80.8in 784 0.0%
235/40-18 3.7in 12.7in 25.4in 79.8in 794 -1.2%
Old May 18, 2006 | 11:26 PM
C5nNC's Avatar
C5nNC
Thanks for specs. I've heard that little of difference is fine. I assume it won't make enough difference to impact speedometer or handling. It's worth benefit of getting Competition compound I guess.
Old May 19, 2006 | 04:38 PM
TTRotary's Avatar
TTRotary
TC will only give problems if the Rear to Front diameter differential is LESS than stock, because the system interprets the higher relative wheel speed of the rear as wheelspin. So more (i.e. smaller front) is OK.
I assume you are looking at a NT01 or the Toyo RA-1 235. That, with 275 40 on the back or 285, should be a good combo.
To 235 / 40 / 18 on front?
