MTI Supercharged...
Old May 19, 2006 | 08:51 AM
big bollas's Avatar
big bollas
Default MTI Supercharged...
I would like to first say "thanks" to Jayson,David and Chris at MTI in Houston,Texas for a job well done on my 2005 C6 M6 Z51.
I had a D1 Procharger,cam kit,headers,60lb Motron injectors and LS2 edit with a wideband tune done by them.
Well on the first run it put down 363rwhp / 360rwtrq not bad for stock!
After the install it was back to the dyno and bam 600rwhp / 510rwtrq.
Jayson then did a little fine tuning and was able to pull it to
614rwhp / 524rwtrq.
That was good but I had plans of installing a "Snow Performance" alky injection kit on it also to keep it safe on summer days .I installed it and also a KB Boost-a-Pump just to be on the safe side.
So back to the dyno it went for retuning and the end results where amazing 657rwhp / 592rwtrq at 9lbs of boost.
Corrected numbers are 645rwhp / 581rwtrq
Thanks to MTI for a job well done and if you are interested in a Supercharger I would highly suggest you call MTI in Houston,TX
Old May 19, 2006 | 10:30 AM
jschindler's Avatar
jschindler
Sounds awesome!
I've known Jayson for quite a while, and I agree that MTI is first class.
Old May 19, 2006 | 10:36 AM
bradb's Avatar
bradb
St. Jude Donor '06-'07
Ditto. Used to go there with my old RX7 and they always did top notch work. Since those early days, they focus on LS products and really know how to make dependable power.
Old May 19, 2006 | 10:41 AM
SHOOTER 49's Avatar
SHOOTER 49
Alot of ponies.
Old May 19, 2006 | 10:50 AM
dollarbill's Avatar
dollarbill
St. Jude Donor '06-'07-'08-'09-'10-'11
WOW - Good numbers. Now you need to get out of that Houston traffic to let 'er rip. Did you do anything to strenghen the bottom end also what about the rear end? How does it drive with this set-up?
Bill
Old May 19, 2006 | 12:32 PM
Mr.Big's Avatar
Mr.Big
Great numbers bro!!!
Jeremy
Old May 19, 2006 | 01:48 PM
Brabus2's Avatar
Brabus2
Outstanding results.... Can you pls post a dyno chart.
Old May 19, 2006 | 02:27 PM
Insom's Avatar
Insom
which cam and which headers?
Old May 19, 2006 | 07:29 PM
vertC6's Avatar
vertC6
Yes, I would like to know the cam specs.
To MTI Supercharged...
