Urgetn HELP.........
Old May 27, 2006 | 10:54 AM
c6nut's Avatar
c6nut
Default Urgetn HELP.........
My 06' C6 keeps blowing relays on my MSD fuel boost pump. I have a Procharger and need more pressure. Can anyone tell me since I think it is time to just change the fuel pump itself to a larger one, how to get to the pump? Is there an access panel by a tire or does the comlete tank need to come down. Does anyone have install instructions for a fuel pump on a C6?
Thanks for the help.
Ted
Old May 27, 2006 | 11:12 AM
VET4LES's Avatar
VET4LES
The entire left tank needs to be removed. The pump is inside.
Old May 27, 2006 | 11:17 AM
c6nut's Avatar
c6nut
Is it a hard chore to do? Do you have any idea how I can see what needs to come off or directions to get it? I am just in a bind. Thank s for the help.
Old May 27, 2006 | 11:24 AM
VET4LES's Avatar
VET4LES
It's a big job. It takes the dealer about 5 hours. The car needs to be jacked up pretty high and then just unbolting things until the tank drops down. The car has two tanks so there are a few lines that connect the two. If you get under the car you can see a protective shield under the tank. That would be the first thing to remove.
Old May 27, 2006 | 11:29 AM
c6nut's Avatar
c6nut
Thank you. I have a lift and will take a look.
Old May 27, 2006 | 11:32 AM
timd38's Avatar
timd38
BIG job. Keep in mind that if you run the car lean, things like pistons start to melt......
Old May 27, 2006 | 01:20 PM
c6nut's Avatar
c6nut
The AFR's are good at WOT 12.00 or less. My problem is it is running almost too rich. We will try a double relay on the boos a pump to see if that stops it from blowing. If that does not work I will change the pump itself.
Thanks for the advice guys.
Ted
To Urgetn HELP.........
