Proper tire pressure
Old Jun 3, 2006 | 11:37 AM
GooseyGoose's Avatar
GooseyGoose
Default Proper tire pressure
Getting my new Supercar tires installed this week.
What is the best tire pressure to run for street use?
I drive it pretty hard at times.
Old Jun 3, 2006 | 11:53 AM
k-line's Avatar
k-line
30psi cold / 32psi cold nitrogen
Old Jun 3, 2006 | 02:04 PM
Miaugi's Avatar
Miaugi
Originally Posted by k-line
...32psi cold nitrogen
That's what I did this week!
Old Jun 4, 2006 | 04:23 PM
shurite44's Avatar
shurite44
I always run the pressure on the door sticker.
Old Jun 4, 2006 | 04:55 PM
dennis50nj's Avatar
dennis50nj
27 front 24 rear cold
Old Jun 4, 2006 | 05:35 PM
sallen619's Avatar
sallen619
30PSI worked fine on the fronts for me...didn't work on the rears.
Old Jun 4, 2006 | 07:25 PM
SPEEDRAZER's Avatar
SPEEDRAZER
Picked up my new C6 z51 last week. Nitro in tires 30/30
Old Jun 4, 2006 | 07:42 PM
VET4LES's Avatar
VET4LES
I have run 30 front and rear for 8500 miles. I am very easy on the car, no burn outs and the rear tires have worn 1/32 more in the centers. I have changed the rear pressure to 28 and see if that helps. There is a disagreement on this forum about the pressure for this condition. Some say with run-flats you should increase the pressure for this condition and others say decrease it. I will see what happens. I am hoping for 25 to 30,000 from these tires.
Old Jun 4, 2006 | 09:47 PM
GooseyGoose
Originally Posted by VET4LES
I have run 30 front and rear for 8500 miles. I am very easy on the car, not burn outs and the rear tires have worn 1/32 more in the centers. I have changed the rear pressure to 28 and see if that helps. There is a disagreement on this forum about the pressure for this condition. Some say with run-flats you should increase the pressure for this condition and others say decrease it. I will see what happens. I am hoping for 25 to 30,000 from these tires.
I guess If I go with 29/30 I should be ok.
Don't expect that many miles on those tires... I just hit 12,000 and it's time for new ones.
Although, I do drive it a little hard at times.
Old Jun 5, 2006 | 02:45 AM
C6V3tt3's Avatar
C6V3tt3
I have the BFG's KDW2 nd I put 38/38. Car feels lighter on its feet and hangs better.
Old Jun 5, 2006 | 07:57 AM
6 speed Sid's Avatar
6 speed Sid
I run 30/30, but I did notice this weekend that when hot the presssure will go to 36. I am going to back off to 29 cold.
Old Jun 5, 2006 | 12:02 PM
Two-Lane Blacktop's Avatar
Two-Lane Blacktop
There are a few variables. The roads you drive on, the way you drive, etc... Try different tire pressures (always cold), and see what feels best to you. I began with the recommended 30 psi, and found 33 psi to work best for me. It feels it hooks better while cornering. BTW, Napa sells a very simple, light and accurate digital tire pressure gauge. If it's not in stock, you can order it through their catalog. The DIC psi = Napa gauge psi.
Old Jun 5, 2006 | 12:09 PM
MitchAlsup's Avatar
MitchAlsup
//pendanic mode = on
The right tire pressure is between 38-40 PSI HOT. So after you get the new tires fitted, start with 32 PSI in them, go out and find that raod where you can drive the snot out of the car SAFELY for at least 10 minutes. Then get out and measure the HOT pressures and write these down. Then take the car home and let it sit overnight and measure the pressures in the morning. This is the pressure you should use when you are going to run the snot out of the car (safely).
//pendanic mode = off
At other times you should set the pressure in the 30-32 PSI range. 30 PSI for gentle cruising, 32 PSI for faster steering response at the cost of some ride quality.
Old Jun 5, 2006 | 12:47 PM
LS WON's Avatar
LS WON
Old Jun 28, 2006 | 12:41 PM
C6RAPTOR's Avatar
C6RAPTOR
We found out at the Putnam Park NCM HPDE that the Supercar tires do not perform well at 38 psig. One of the GM engineers that was at the event told me that at 38 psig you will damage the center of the tire.
28 to 29 psig cold will end up being 30 to 31 psig on the road on a 80 F day with air. Nitrogen is best at 30 psig.
Old Jun 28, 2006 | 01:52 PM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
I learned that the hard way
Old Jun 28, 2006 | 02:11 PM
TRColin's Avatar
TRColin
6th Gear
To start, tires should be inflated to the placard pressure indicated on the vehicle.
A tire will gain or lose 1 psi for every 10 degree change in temp. so it is recommened to set the pressure when cold.
To Proper tire pressure
Old Jun 28, 2006 | 02:24 PM
bradb's Avatar
bradb
St. Jude Donor '06-'07
Well said, Mitch.
Old Jun 28, 2006 | 02:34 PM
jimman's Avatar
jimman
I got 36K fronts and 31K rears and wear is even, that's with 29 lbs front cold and 28 lbs rear cold.
Old Jun 28, 2006 | 03:40 PM
C6RAPTOR's Avatar
C6RAPTOR
