Callaway Honker
Old Jun 26, 2006 | 02:19 PM
LOS ANGELES PI's Avatar
LOS ANGELES PI
Originally Posted by TLewis4095
In all our side by side tests the Calloway Honker beats all comers.
We recomend it as the preferred RevXtreme air intake.
I do too. Look at what my dyno is with the Honker.
Old Jun 26, 2006 | 04:54 PM
GMRULZ's Avatar
GMRULZ
I also bought a honker, but the drill bit is missing. Can anybody tell me what size a #4 drill bit is????
Old Jun 26, 2006 | 06:08 PM
LOS ANGELES PI
It is basically the same size as the rivets you will be using to secure the housing too. If you want, pm me your mailing address and Ill be happy to mail you the one they sent me.
Be sure to use high temperature gasket sealent between the lower assembly and the radiator baffle. Makes a nice airtight fit.
Old Jun 26, 2006 | 08:25 PM
dirty eddie's Avatar
dirty eddie
I added a scoop to better direct air to the filter element. Also while you have the radiater shroud out, cut the bottom corners off at a 45 degree angle and it will go back on easier.
Old Jun 27, 2006 | 04:51 PM
GMRULZ's Avatar
GMRULZ
thanks guys!
Old Jun 27, 2006 | 06:59 PM
Lionheart's Avatar
Lionheart
Originally Posted by z060ntrack
How long did the Honker take with "friends" to install. I was about to purchase the Lingenfelter unit that you can order with the pre cut shroud.
I have an '07 convertible on order and am considering the Honker, Lingenfelter, SLP Blackwing and Power Flow (a low probability). Did you consider all these options and still go with the Honker? I'd appreciate someone helping me narrow down the field. Thanks!
Old Jun 29, 2006 | 09:45 AM
mcv's Avatar
mcv
#4 drill bit is .209" in diameter.
Please contact Callaway (860) 434-9002, and we'll send you a replacement drill bit.
Sorry for the inconvenience.
Old Jun 29, 2006 | 09:54 AM
mcv's Avatar
mcv
I hesitate to post the attachment because it's an advertisement, but I wanted to show you the exploded view of the C6 Honker, so you could see how it works and compare the design features and construction quality to the other brands you mentioned.
Old Jun 29, 2006 | 10:02 AM
z060ntrack's Avatar
z060ntrack
Did you test the Ligenfelter unit in your side by side tests?
Old Jul 2, 2006 | 11:23 AM
tsgrayson's Avatar
tsgrayson
I will be getting mine soon from a forum member
Old Jul 3, 2006 | 08:41 PM
GMRULZ's Avatar
GMRULZ
I sure will thanks guys!
Old Jul 4, 2006 | 01:53 PM
jdurhan's Avatar
jdurhan
well I dont know but lookin at the pics of I guess is the shroud, it looks to be a MAJOR undertaking to put the honker on a stock C6. I was hoping to put one on, I originally understood it to be an easy install. Can anybody clear this up for me.
