C6 Break in
Old Jun 12, 2006 | 10:04 PM
MotownR's Avatar
MotownR
Cruising
Default C6 Break in
I know your all tired of talking about break ins but I need a solid answer. I'm getting my first vette in a couple of weeks from the museum delivery and have to drive it to detroit. Is this a good idea? I don't care if i have to go 50 the whole way ill do it. Once it is back should i put new fluids in it? these kind of questions are the ones i need help with, i would die if i f something up. Thanks
Old Jun 12, 2006 | 10:23 PM
glennhl's Avatar
glennhl
You are right, there is a lot of debate, but one thing that everyone will agree on is don't let it stay at one rpm. You can run 50, but do it in 4th, 5th, and 6th. I've heard that keeping it below 50 mph is not as important as keeping it below 3000 rpm.
Old Jun 12, 2006 | 10:30 PM
MotownR's Avatar
MotownR
Cruising
Thanks glen, do you know how often i sould change the rpms? every few minutes, hours? i know when i broke my motorcycle in i was constantly moving the throttle and didn't let it sit at all.
Old Jun 12, 2006 | 11:18 PM
glennhl's Avatar
glennhl
I probably changed gears/rpms about every 10 minutes.
Old Jun 12, 2006 | 11:19 PM
glennhl's Avatar
glennhl
I probably changed gears/rpms about every 10 minutes. Also, you'll find it impossible to drive at 50 and under during the first 500 miles. I had some freeway driving during the first 500 and I drove 65 to 70 or I would have been killed!
Old Jun 12, 2006 | 11:49 PM
Street Beast's Avatar
Street Beast
I would defnitely drive through a range of RPM's and stress the motor after 500 miles. Your car will be a different car after about 2000 miles. At about 2300 miles my engine was nice and lose and finally hit the rev limiter without hesitation. The power just surges once broken in.
Have fun...
Old Jun 12, 2006 | 11:58 PM
StarJack's Avatar
StarJack
A common theme seems to be you're breaking in the rear end as much (or more) than the motor. Glennhl gave you good advice. Just don't be dragging, drifting, or hitting triple digits back to the motor city!
And post pics when you get home!
Old Jun 13, 2006 | 12:20 AM
Vette_DD's Avatar
Vette_DD
And don't hit the brakes too hard the first 200 miles.
Obviously, don't use the cruise control those first 500 miles.
Old Jun 13, 2006 | 12:38 AM
d_bravo33's Avatar
d_bravo33
Ask your guide at NCM. He'll give you some specific suggestions. Mine said they were all in a question-answer session with Dave Hill before he left and asked this question.
His suggestion: vary the speed every few minutes, someplace between 45 and 70, even if you're on the Interstate. This engine and rpm doesn't have to be held under 50 mph as the manual suggests, he said, and the speed should be varied because of the transmission and differential as much as the the engine. New gears, driven at a constant speed, can wear in a pattern and that can cause rearend noise later. After 500 miles, gradually increase speed and consistency.
Right or wrong, it seemed reasonable to us. We drove our MN6 home 2,600 miles and were driving at or above the limit by the time we reached California. With 4K+ now, it hasn't burned any oil and has a fine power curve.
Old Jun 13, 2006 | 06:41 AM
Patman's Avatar
Patman
Actually, the proper way to break in new brake pads and rotors is to make 5 medium stops in a row to heat it up, then make ten super hard stops in a row (without coming to a completely stop) in order to super heat up the brakes. Then drive for 10-15min without stopping, to cool them off.
Old Jun 13, 2006 | 08:07 AM
CYA-Vett's Avatar
CYA-Vett
Drive it like you stole it.
I laid rubber out of the dealers lot, while I waved...
It was at the track 150 miles later....
1,500 miles now, zero problems.
There is no break in, my warranty expires at 36,000 miles, not 36,500 miles.
Old Jun 13, 2006 | 08:14 AM
Geneus's Avatar
Geneus
Yep...he dropped the clutch at 5000 rpm right off the showroom floor.
Old Jun 13, 2006 | 08:15 AM
CYA-Vett's Avatar
CYA-Vett
I launched harder leaving the delaer than I do at the track
Old Jun 13, 2006 | 04:24 PM
MotownR's Avatar
MotownR
Cruising
Thanks everyone, just so you guys know its my 25th b-day and I sold a 00 ws6 and an 05 STi for this vette. It is a 3lt z51 mn6 in victory red/cashmere with chromies and the roof package (no holding back) I plan to have it even when were all driving hovercrafts. I will post pics as soon as I get back.
Old Jun 13, 2006 | 04:30 PM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Good luck, what a birthday present at 25. I got mine for a birthday present at 47...Have a great trip!
Old Jun 13, 2006 | 07:14 PM
VET4LES's Avatar
VET4LES
I agree with Bravo33. Ask the people at the museum. I followed their suggestions and have had no problems.
Old Jun 13, 2006 | 07:53 PM
Tightwad's Avatar
Tightwad
I do it the same way I do any engine.
Warning if you get arrested dont blaim me!
I suggest you choose a very deserted location for this!
1. Bring Car up to normal operating temperature. Place in 3rd Gear. Accelerate 2000-4500 rpm @ 50% Throttle, Allow car to decelerate back to 2000 rpm under engine compression braking only. Repeat. (Do 5 Times Total.)
2. Drive car 10 minutes to allow to cool. Place in 3rd Gear. Accelerate from 2000-5500 rpm @ 75% Throttle, Allow car to decelerate back to 2000 rpm under engine compression braking only. Repeat (Do 5 Times Total)
3. Drive car 10 minutes to allow to cool. Place in 3rd Gear. Accelerate from 2000-6400 rpm (make sure not to hit rpm limiter) @ 100% Throttle, Allow car to decelerate back to 2000 rpm under engine compression braking only. Repeat (Do 5 Times Total.)
4. Drive car 10 minutes to allow to cool.
Car is now ready for track with rings fully seated.
Gene
To C6 Break in
Old Jun 13, 2006 | 11:11 PM
Purdue's Avatar
Purdue
Now that is true...never thought of it that way!
Old Jun 13, 2006 | 11:21 PM
MotownR's Avatar
MotownR
Cruising
Wow now that sounds like an intense break in. I probably cain't do it that way but that is the coolest way to break in an engine that I have ever heard. Thanks a lot
Old Jun 14, 2006 | 09:08 AM
Blue02Z06's Avatar
Blue02Z06
i had the museum delivery and i was told by roger on the end of the line that i should give it about 50-100 miles to let the clutch seat itself and warm up a few times then give it absolute hell for the rest of its life. He then of course told me "if you can break it, we'll replace it" So that pretty much eased my mind on the way home when i lit up the tires on the Corvette Testing Grounds at the back of the plant.
Dave
