C6 Halltech intake coming apart?
Old Jun 20, 2006 | 12:07 AM
glennhl's Avatar
glennhl
Jim,
Thanks for the numbers. Now what does 2 inches of water less pressure drop do for power? By my estimation, 2 inches is .07 psi, which if you divide by standard atmosphere of 14.7, gives .48% higher inlet pressure. I can't remember the conversion for power, but isn't it something like 70%? So 400 * .48/100 * .7 = 1.34 hp. How much less is the restriction of the bridge? I assume that's where the rest of the power increase comes from.
Thanks,
Glenn
Old Jun 20, 2006 | 12:17 AM
cbrf4i1's Avatar
cbrf4i1
Originally Posted by Jim Hall
Tomorrow, I will personally get a new C6 System, sans the connector hose, off to both of you that had problems with the bridge.
I will make sure the new filter is pre-installed on a brand new bridge.
I'll get one off to both of you as a warranty claim.
I you have any questions, please contact me at 262-965-4300 or email my personal address at jim@CorvetteC5.com.
Thanks,
now that is customer service.....
Old Jun 20, 2006 | 12:20 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Originally Posted by glennhl
Jim,
Thanks,
Glenn
It depends on the HP level of the motor you are dealing with, but in the case of the C6 at 400 HP, that figure is approximately 2% for every 1" of restriction, or 8 RWHP. Our first customer actually got 11 RWHP, on the same day, same dyno, same conditions.
I got these figures from Donaldson Company that does more research than most companies on airflow.
Call me tomorrow. I have another option that will get you down to -8" with the stock C6 MAF sensor you are using, and -5" with the 04 Z06 MAF. This is done with a new version Warhead Filter, which is much lighter, and flows better than the SSM. I do not have them in stock yet, but they will be by months end.
I understand the overtightening senario. You are entitled to a new system under warranty.
Old Jun 20, 2006 | 12:30 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Jim,
Thanks,
Glenn
Found it:
Here is a link to the entire Donaldson report on the Halltech C6 Stinger:
http://www.corvettec5.com/Halltechtest.pdf
This is in Kpa. The numbers posted on restriction is with the entire intake system hooked up, not just the filter. The stock MAF is used in all testing for stock vs. Halltech.
Interestingly, we get bashed all the time on the forum about our system and cold air.
I took a TECH 2 onboard my buddies C6 the other day, and watched the IAT vs the OAT, both being recorded on the TECH 2. It was 78 outside and 80 to 82 degrees at the IAT sensor. 2 to 4 degrees hotter than the outside temp, with our ICAI.
The beauty of this system, is that it does not direct airflow at the filter but rather into the intake vestibule area where it can be used by the intake as needed. No chance of water damage or mud from dirt and grim ingesting into the engine during the rain.
Too much is made over hydrolock, which is a rare occurance, and generally only happens during flooding. Our system is in the stock location, so the risk of this is minimal and much less than the bottom breathers.
I have a video somewhere that shows me flooding the filter with a hose with the engine running, and then driving down the road and doing a burnout. The filter is Totally saturated.
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
www.halltechsystems.com
Old Jun 20, 2006 | 12:44 AM
glennhl's Avatar
glennhl
Found it:
Jim,
You are a gentleman and I agree you give wonderful service. Looks like this is not far off from what I was calculating. For just the filter, you gain 2 inches, which is .5 kilopascals. So for a 400 hp, .5 kilopascals would be 2.5 hp according to Donaldson's numbers. So it looks like they are using the straight ratio and not multiplying by .70 for horsepower versus inlet pressure.
Thanks,
Glenn
Old Jun 20, 2006 | 05:42 AM
midnite902's Avatar
midnite902
This flow chart was done by Donaldson Company, prior to Halltech's involvement with the new high flow Z06 PowerCore filter project. They were our competitor at this point, making this an independent analysis. We paid them to run these tests.
So, this statement indicates that before Halltech was involved Donaldson had already developed the Z06 Powercore filter? I thought Halltech developed this filter?
Old Jun 20, 2006 | 10:11 AM
AFVETTE's Avatar
AFVETTE
So far my Halltech Stinger is working as designed. I did clean the inside lip like the video shows. 1000 miles so far w/o a problem.
And I can feel the difference over the OEM intake. I'll get some dyno numbers (befofe and after) in a few weeks.
Tom
Old Jun 20, 2006 | 11:19 AM
Whiterock1's Avatar
Whiterock1
Certainly Jim Hall deserves praise for his commitment to customer service. That is rare in general, but seems to be the rule on this forum's supplier base. With respect to the Stinger v K&N Aircharger: I really do not see any difference. The SLP also looks the same. I like the design--greater surface area to bring airflow through, no cutting of the shroud, and better flow and protection than stock. I chose the K&N, but would have no problem with either of the others. But, again, I see [I]no[I]difference in design. I guess it's a question of go with whomever you have the best history.
Mike
Old Jun 20, 2006 | 12:29 PM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
I got one of the first 10 made. It has been on for over a year and have not had this problem.
Old Jun 20, 2006 | 02:11 PM
Irv's Avatar
Irv
Originally Posted by Brett Hunter
Make sure that you clean the filter and the airbridge where they join real well. I found that during shipping some of the oil from the filter can make it on this surface making it very easy to fall off.
Perhaps a good point for Hall to add to his printed instructions, which don't mention this. Nonetheless, when I installed mine it had no slipperiness whatsoever, and it functioned perfectly for for about 3,000 miles (just a guess).
Old Jun 20, 2006 | 02:34 PM
Irv's Avatar
Irv
Mike
There are differences between the K&N and the Stinger. The K&N employs far deeper neck penetration into the filter and double band clamps. See for yourself.
http://www.pfyc.com/store/merchant.m...&AFFIL=froogle
The Blackwing is an even better design, which uses a mounting plate that holds the filter assembly in place.
http://www.pfyc.com/supportfiles/c63015install.pdf
Old Jun 20, 2006 | 03:13 PM
RBYCC's Avatar
RBYCC
Blackwing also uses the stock mounting posts for the airbridge and a mounting rail for the lower part of the filter. As secure and as rigid as the stock setup
Old Jun 20, 2006 | 03:17 PM
  #33
Irv's Avatar
Irv
My apologies. Someone PM'd me and said the K&N uses the same type of mounting plate as the Blackwing. I stand corrected.
Old Jun 20, 2006 | 05:48 PM
  #34
RBYCC's Avatar
RBYCC
Tom
Tom
Is the connection from the air filter to the air bridge flexible like the SLP?
Or does the filter just slide into the neck of the air bridge ?
Ed
Old Jun 20, 2006 | 05:55 PM
  #35
AFVETTE's Avatar
AFVETTE
Originally Posted by RBYCC
Tom
Ed
The air bridge fits inside the air filter neck by about 1/2". The filter is also much lighter than the Blackwing. As you know I was having CEL and surging with the BW which is why I returned it. I have no such issues with the Halltech.
Tom
Old Jun 20, 2006 | 06:04 PM
  #36
RBYCC's Avatar
RBYCC
Tom
I wonder if the Halltech would benefit from the accordion style flex connection per the SLP? It seems that those who had problems with the filter falling off were caused by not able to maintain or over tighten the air filter neck. If both were a heavier gauge of plastic then you would draw down on the flex connector, and not distort the housing like some are doing.
Did you install the Halltech CAI?
I removed my stock fascia extension on Sunday and cut it open ala Halltech. Not sure of any performance gain, but it seemed to change the overall sound of the car and mellow the GHL catbacks.
Also it appears that the Halltech filter is larger then the SLP?
Old Jun 20, 2006 | 06:11 PM
  #37
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
For those of you conscerned about the intake flapping around, I found a possible solution. It's from WCC. I can't find it on their website but it's in their catalog. It's a chrome stock air tube cover. It bolts right into the factory hold points. Granted it's an extra $50 and some may not like the styling. But put a nice C6 flag emblem on it and you've got a good show piece and something to hold the inlet tube down. That's if it fits. Just a thought. Wish I could show you guys.
To C6 Halltech intake coming apart?
Old Jun 20, 2006 | 06:42 PM
  #38
Irv's Avatar
Irv
The Halltech filter is much larger than the SLP. I don't think an accordian design would make any difference in filter assembly security. As I mentioned in a previous post, the hood liner clamps down on the Stinger's plastic bridge, holding it in place. My theory is that the problem is the filter itself being unsecured, perhaps coupled with its heft.
I've been reading several posts here alleging that my installation was still at fault, but in reviewing my memory of the process, most of what sticks out at me was attention to detail. Making sure the filter was laying perfectly flat on the shroud, making sure all of the clamps were aligned properly, tight... and I remember even testing it manually for security. And to answer a perfectly reasonable question I was asked, NO ONE else but me services the car - ever.
I have a lot of trouble believing any intake mod would affect the sound of the exhaust. Two independent systems. Reminds me of audiophiles that believe the choice of power cord affects the sound of pre-amps and CD players.
Old Jun 20, 2006 | 10:45 PM
  #39
KDH's Avatar
KDH
Has anyone else ever had their Halltech C6 intake come apart after it was installed? Hall claims mine was assembled improperly, and that's why it happened, but I'm not so sure. (I assembled it myself after reading his instructions.) I opened the hood a couple days ago to find the filter dropped away from the plastic bridge. Apparently I've been driving for a day or two without an air filter!
I'll accept Hall's explanation if no one else has ever seen this happen after months of driving, and simply sell the intake for a fire-sale price.
After the filter on the first Halltech I bought kept slipping off, I ended up overtightening the clamp on the air bridge, causing it to collapse around the edge. I contacted Jim Hall, who immediately sent me a new one. That one didn't collapse, but it still kept working itself loose from the filter (albeit more slowly). I ended up taking it off and reinstalling the factory unit.
I'd like to try it again, but don't hold out much hope for success the third time around. It seems to me that supporting the unit from the bottom of the filter would alleviate the problem. Any thoughts on a good way to do this, or if this would even work? Thanks in advance for any suggestions.
Old Jun 20, 2006 | 11:20 PM
  #40
glennhl's Avatar
glennhl
Jim,
Thanks,
Glenn
Jim,
I agree with the numbers, you get around 2.5 hp for the bigger filter, but where does the rest come from if it's good for 10 hp?
Thanks,
Glenn
