C6 Halltech intake coming apart?
I'd like to try it again, but don't hold out much hope for success the third time around. It seems to me that supporting the unit from the bottom of the filter would alleviate the problem. Any thoughts on a good way to do this, or if this would even work? Thanks in advance for any suggestions.
On future systems, we may include a tube of adhesive to augment the sealing of the filter.
I agree with the numbers, you get around 2.5 hp for the bigger filter, but where does the rest come from if it's good for 10 hp?
Thanks,
Glenn
I have read people gaining 10 hp and I've also read people gaining only 2 hp. I admit that a filter element that has 2 inches of water less pressure drop is good for 2 hp. But I'd be surprised if the aftermarket bridges have much less pressure drop than the factory one. The next time I'm on a dyno, I'll take in my stock filter setup to get a back to back.
Thanks,
Glenn
Thanks for the response. I wasn't trying to slam you or your product. In fact, I'm very impressed with your outstanding level of customer service, and I should have contacted you directly. I'm going to try the adhesive, but is there any particular brand I should use? As I recall from the installation instructions, you advised against using any type of silicone product to secure the PCV valve, as it might affect the O2 sensor. Thanks.
The filter is heavy, which makes cleaning the 1" flange thoroughly with Acetone mandatory to remove any oil that may have worked its way into the flange area during shipment. This information is on our installation video.
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
www.halltechsystems.com
Thanks,
Glenn
I think Jimman has done more dyno testing of our C6 Stinger than anyone else on the forum, he might be able to relate his experiences to us.
You can also check with our Warehouse Distributors, 21st Century Muscle Cars, LG Motorsports, Corvette Central, A&A Corvette, Corvette Accessories Unlimited, Livernois Performance, Norris Motorsports, Extreme Motorsports, Dragon's Breath Performance, Finish Line Performance, New Era Performance, and Corvette Garage. All are forum sponsors, and none have ever reported any issues like this to Halltech. They sell our C6 Stingers by the truckload and must have pretty good results. Give them a call.
The Halltech C6 Stinger setup was without programming, correct?
Halltech without programming was 9.5 RWHP over just the OE stock intake with programming?
So what were the Halltech numbers with programming, or is programming unnecessary in your opinion with our intake?
