MN6 and Diff oil plug sizes/access
Looking at them the diff plugs appear more difficult to access. Has anyone had a problem getting a hex key on these? Is loosening them tough from the factory?
Transmission fill plug torque (Size 3/8" square drive) 20 lb ft
With all the fuss over Redline fluids and Amsoil, I don't know what is best.
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Same thing here but the factory fill for the transmission fluid is not synthetic just regular ATF DEXRON III (H) or now DEXRON IV. Most of these synthetics say friction modifier already added and not needed.
Some have added two bottles to insure they eliminated a stubborn problem, but that's generally overkill. IMO, the lubricity of synthetic lubricants is not enough different from mineral oil lubricants to allow you to skip the additive. If you don't need the additive, putting it in anyway generally won't do any harm.
On the other hand, if any distributor's bottle says use of limited slip additive is NOT REQUIRED with their product, I would not use limited slip additive. It's probably not required because the additive has already been mixed into the product, not because their synthetic lubricant alone is so "slick" it doesn't need it.
That is Red Line you don't need to add anything extra.
Amsoil says you can add their extra friction modifier but how do you know if you need it without filling it up first? I mean you want to do this all in one shot not going back and forth draining and changing a few times and listening for clunking or whatever noises. So you might as well add the extra friction modifier if you use Amsoil.
Note that Redline makes a 75w90 for diff without limited slip clutch plates called 75w90NS. This diff fluid would need the 4 oz of additive as it doesn't come with any.
Don't know now if I want to perform that rear differential change of fluid to get any metal shavings out at 11,100+ miles as I hear about more rear end noise problems on the C-6 which I haven't had that problem "If it ain't broke don't fix it". I read some TSB I believe that if it is a first time fix that dealer will change fluid. If a second time fix after first time when fluid was changed then they replace the rear end inside
Here is a quote off the AMSOIL corporate literature for this product:
"NOTE: AMSOIL Synthetic Gear Lubes do not require the use of this additive. However, not all differentials respond the same and if chatter is noticed, the addition of AMSOIL Slip-Lock will eliminate it. For chattering differentials not running AMSOIL Gear Lube, this product is an excellent solution to the problem."
If you were going to do this fluid change as preventative maintenance, you should have done it at 3K! I'm pretty sure your ring gear and pinion have already been pitted and scored by all those metal shavings floating around in there, and your A4 is sloughing off clutch disc material like a shedding snake. Listen carefully when you drive...I'll bet it's already making noise...it'll sound like a low moan that increases in frequency with speed. It'll probably fail at about 36 months and one week, or 36500 miles, "whichever comes first".
Only kidding.
LS WON, in spite of what **** Corvette owners do about maintenance, I would bet $100 that 95% of all cars in the junk yard still have their original factory fill in the differential and transmission. It's usually collisions that put cars in the junk yard; not the poor maintenance practices people follow. Just follow what the General says to do for maintenance, and use the approved fluids they recommend, and your car will outlast you.
Only kidding.
Actually I would have done rear end differential and auto trans right after 1,000 miles when I did the engine oil change for metal shavings but had never heard of doing the rear end or auto trans for this like the engine oil at 1,000. So now I'm at 11,100+ miles. My dealership recommends to do the Transmission service at 25,000 miles and do the rear end service at anytime.
So then you would suggest following the General's orders??
I have the manual right in front of me.
If I were to do that then the rear end 75W/90 synthetic fluid never needs to be changed unless it leaks.
The A-4 auto trans use ONLY DEXRON III (H) or now DEXRON IV which replaced DEXRON III (H) which I believe is an ATF fluid and not a synthetic fluid which means I can't use a synthetic fluid in the auto trans?
It says in the manual to change the Automatic transmision fluid and filter every 50,000 miles for severe service or 100,000 miles if not severe service.
I have never known anything else but severe service since wherever you go there is heavy traffic and end up idling in that all the time.
"Notice: Use of automatic transmission fluid labeled other than DEXRON-III, Approved for the H-Specification, may damage your vehicle, and the damages may not be covered by your warranty. Always use automatic transmission fluid labeled DEXRON-III, Approved for the H-Specification".
This means I can't use a synthetic Fluid in the automatic A-4 Transmission
*****: I'm so
I can't handle this new technology
Quit fretting about not being able to throw your money down a synthetic oil rathole...by the time you put on 100K miles, they'll probably be using synthetic Dexron XII. Happy Motoring.
I go by severe service schedule because of the prolonged idling in traffic jams and stop and go driving.
For the rear end it doesn't say anything about changing it in the owners manual other than if it leaks. Dealership told me I can change rear differential fluid at any time.
Also knowing I am putting in better lubricants to protect ring & pinion gears and auto transmission is comforting over what is in there now which would also be dirty too.
