Intake manifold
Old Jul 1, 2006 | 11:13 PM
Shrike6's Avatar
Shrike6
Somba master
Cruise-In 7, 9 & 12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '07-'08-'09-'10-'11
Default Intake manifold
Two intake manifold questions:
1. Is the black plastic over the intake manifold removable, or is it part of the manifold?
2. Does anyone have photos of the stock manifold?
GM
Old Jul 1, 2006 | 11:20 PM
johnodrake's Avatar
johnodrake
Moderator
GM
The manifold is composit. I think what you are looking at is the manifold.
Old Jul 1, 2006 | 11:35 PM
Shrike6's Avatar
Shrike6
Somba master
That's what I thought, but wasn't sure.
I've heard so much about cleaning up the casting and porting it getting good gains for an easy install.
Just thinking here.
GM
Old Jul 2, 2006 | 11:59 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Just thinking here.
GM
Gary,
Do the FAST intake. Ben has one. It requires a slight Firewall mod to fit. Conservative reports are 15-20 RWHP for just the FAST. Only thing I don't like about the FAST is the stupid Gray color. Paint it before the install. Tony is best for that install. Your OEM 90mm throttle body is probably just fine.
www.fuelairspark.com
Old Jul 2, 2006 | 01:20 PM
Newton06's Avatar
Newton06
See my recent post on cleaing/porting the OE intake.
The Fast is a good mod, but expensive, and requires cutting the firewall, and various other changes to work.
For a fraction of the cost, you can have the OE unit ported with similar gains. You can also do it yourself like I did.
To Intake manifold
