CEL w/lt headers & hf cats
Old Jul 4, 2006 | 10:05 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Default CEL w/lt headers & hf cats
I have Dynatech headers w/high flow cats on my '06 A6. The system throws an error code telling me I have no cats. I have it reset and, within two weeks time, it comes back on. The service mgrs at several dealers have told me the same story, the cats are working ........... to good! There are no simulators on the market yet and I am reluctant to have the CEL function shut off with a software edit as I would then not become aware of any major engine problem should one occur. My '05, M6 did not have this problem. I understand that the engine software is drastically different between the '05 and '06 yrs. Is any one else with headers on '06 having the same problem ? If so, have you solved it ? And, if so, how. I really don't want to get rid of the headers if I don't have to. However, in TX, they won't pass the car for it's annual safety insp. if the CEL is on. Wow, I can already see the parts for sale wolfs pacing outside the den window.
Old Jul 4, 2006 | 10:15 AM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
My 05 mn6 has been throwing this code multiple times over the past 18 months. Started when I put the Dynatechs on and continues repeatedly. So, I went to Wal-Mart and bought a $70 OBDII and simply clear the code.
BTW, I did have my dealer run a diagnostic and they found nothing that would indicate a CEL.
Old Jul 4, 2006 | 10:25 AM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Happy 4th Jeff. I to have the code reader you have. Unfortunately, it isn't CAN enabled. Heck, the dealers even had to buy new and more expensive equipment to read the '06 GM cars. The new CAN enabled reader is around $300. I've already done a web search for it. In TX, they plug into the data port under the dash. If the CEL shows that it has been shut off with fewer than a certain # of read cycles (approx 50driving miles), the car flunks ! If I have to remove the headers to pass my safty insp, they are history. The parts wolfs are circling ever closer.
Old Jul 4, 2006 | 11:49 AM
AFVETTE's Avatar
AFVETTE
I bought mine for under $75 and it works like a champ, several club buddies have borrowed it after installing various LT headers and intakes.
http://www.diydiagnostics.com/index2.html
It's the second reader for $69.99
Tom
Old Jul 4, 2006 | 12:06 PM
schilitj's Avatar
schilitj
I have the Innova 3030 from Wal-Mart, $69 and it reads everything. www.canobd2.com
Good luck
Old Jul 4, 2006 | 01:15 PM
haljensen's Avatar
haljensen
4 MY EGO; In the major cities and surrounding counties in Texas all it takes is an inspector with an attitude to fail you if you have headers. The visual part of the inspection calls for stock cats in the stock location.
Old Jul 4, 2006 | 08:40 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Good luck
Amazing! I drive over to a friend's house to use his code reader to shut off the CEL. What's he use ? The Innova 3030 Guess what I'm buying this weekend. Duh ! He explains to me that the reason the light kept coming back on was because the darn dealers weren't clearing the code completely out of the system. All the tech was doing was shutting off the light. Evidently there was another step they were not doing. Kind of like cleaning out unwanted cookies on a computor. To all, thank you for your help. Michael
Old Jul 4, 2006 | 10:19 PM
schilitj's Avatar
schilitj
Glad to be of assistance, now have fun!
Old Jul 4, 2006 | 11:07 PM
SpinMonster's Avatar
SpinMonster
What was the code? The number not what they told you.
Old Jul 4, 2006 | 11:56 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
420 and 430 if I remember correctly. Right and left cats not heating up fast enough.
Old Jul 5, 2006 | 12:54 AM
glennhl's Avatar
glennhl
I thought any normal sim would work? Do the sims not work with the 06's? Also, if you turn the code off it's the same as having the sims. I had codes on my 01 Z28 with long tubes and high flow cats and I kept clearing them with my Actron OBDII code reader. I got really tired of doing it every 3 days so I finally had the codes turned off with HPtuners. It was never an issue after that. But I know what you mean of not knowing when you have a real problem.
My 06 Vette has LG long tubes with high flow cats and knock on wood, I have never thrown a code since I put them on about 2 months ago. If they start throwing codes I'll buy HPTuners now that it's available for an A6 (for at least the engine functions).
Last thing, I read somewhere that people put in the plug saver extensions (that you buy from the HELP section at Checkers) and that sometimes keeps it from throwing codes. Never tried it, sounds kind of hokey to me, but some people say it works.
Good luck,
Glenn
Old Jul 5, 2006 | 01:21 AM
cbrf4i1's Avatar
cbrf4i1
unfortunely it wouldn't work, at least not on the 06.
Old Jul 5, 2006 | 03:54 AM
shopdog's Avatar
shopdog
Are you running ceramic coated headers? If not, having yours coated will hold the heat in the exhaust gases and let the cats heat up quicker, like they're supposed to. That should solve the problem you're having.
Old Jul 5, 2006 | 06:22 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
I checked with A&A ............. NADA !
Old Jul 5, 2006 | 07:23 PM
GMautotech's Avatar
GMautotech
Those 2 codes are for "Catalyst System Low Efficiency Bank 1 & 2" Basically your hi-flo cats are not efficient enough. I wouldn't worry about removing the rear O2's from the PCM calibration. The only thing they are for is to monitor the cats. Removing them will not 'mask' other potential problems you may have.
Old Jul 5, 2006 | 07:33 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
That's why I'm leaving things as they are. In no way would I have the CEL tuned out of the system.
To CEL w/lt headers & hf cats
