The shorties may be CARB certified but you won't get the gain that you'd see with the long tubes. Sorry I don't have the actual numbers to post but....that's my story and I'm sticking to it
If remaining emissions legal is that important (and it is) I would sooner just stick with the stock manifolds and find the power somewhere else.
Double Ditto.
I am sure you will not like this candid feed back espessially coming from yellow Vette owners and perceived yellow vette owners, but you will get over it.
Double Ditto.
Most of the test reports and claims I've seen indicate that the long-tube headers are good for about twice the HP gain (25-30) as the short-tube models (10-15), but most if not all of these tests are comparing long-tubes with high-flow cats (or no cats) to short-tube headers with the stock cats. I'm not sure that the difference wouldn't be smaller using the shortys with Random cats.
In addition to the emissions issue and possible codes due to cold cats and O2 sensors there's the matter of stuff hanging out under the car. The cats are so nicely tucking in out of the way where they are!
Double Ditto.
And since you posted that yet ANOTHER yellow Vette owner posted!
Does anyone know if he could use Z06 exhaust manifolds and gain power?
I'm pretty sure they'll clear the frame/engine bay for fitment but the port shapes are different I think, might be some potential turbulence there. Plus the Z06 cats and H pipe are different (bigger) as well.
Using the whole Z06 system might be one option though.
Thanks, thats what I am seeing from some other sources, about 10 hp versus 30. But like you said thats with hi flow cats and an x-pipe.
does anybody happen to know of anyone selling a random cats setup for the stock location? and I guess while we're at it, a x pipe replacement for the stock h pipe.
Doing this would also violate the law, so you might as well go with long tube headers. It has been a while since I read it, but I believe the only legal way to replace a cat is if it is damaged.
Yep, they're broke alright, they don't flow enough.
Hey I agree with you. I have LG's, high flow cats, and an xpipe.
Just pointing out that shorty's with cats not from the factory would be just as illegal. Unless of course as I pointed out they had to be replaced due to damage.
They're probably not legal, but it's not like anyone will find out without practically dismantling the car and having another C6 to compare with.
I'm not sure anyone makes an X-pipe that they will guarantee to fit with the stock mufflers, but then if you're spending over 2 grand on headers, cats and x-pipe you might as well get a nice catback anyway.
Thanks!!! OMG, $339 each side... ouch
Well, at least I have a second option now. Thanks everybody!!!
True but the same could be said for long tube headers. If you are in a state with no visual inspection and especially if you are in a state with no type of requirement your chances of getting busted for this are slim to none.
My point is if you are going to the trouble to get headers, and you decide to replace the cats. You may as well go with long tubes, because both options violate the letter of the law. Only way to stay compliant is to use approved shorty headers and keep your stock cats, period.
Now as far as hurting the environment. I bet my LG's high flow cats and corsa cat back would test out clean anyway.
Ok, I am done here. I think maybe I am missing the point or something.
Personally, I'm not worried about getting busted for illegal exhaust, and I doubt that there's any significant difference in emissions. I do like the way the factory cats tuck up into the engine compartment, and the pipes are in the tunnel leaving a very clean underside with little to scrape or affect the airflow under the car. That's my main interest in the shortys.
Good point. I live in the **** state of new jersey, so whatever i do either comes off in fours years when i have to get it inspected. Or I move on to another vette, unless of course GM is french and japanese, if thats so, i might as well go ford, if they are still american, or porshe if not.
I'll walk before i drive a frog or japanese car. Its BS i cant say J A P like this ***
guess they programmed this board, damn japs
