I have had my foot slip off the clutch pedal several times, mainly when standing for a long traffic light in heavy traffic. I am driving a 2005 6-speed manual. In this case, with the engine idling, the engine dies when my foot slips off the clutch.
The Vette is a dream car to drive, am highly pleased with it. The performance is remarkable. Ordinarily, I wear rubber-sole shoes when driving. Frequently, however, we are attending events where we dress up to some extent, and that's when the clutch is likely to be a problem while wearing loafers or other leather-sole shoes.
The Chevy dealer is reluctant to recommend a modification, due to fears of possible legal action if I have an accident.
The clutch pedal is metal and very narrow, only a couple inches wide.
I am thinking about cutting a piece of tread from a truck tire, forming a rectangular piece about 4 inches wide by 2 inches. I think this can be held on the clutch pedal with a vehicular water hose clamp. I would like to have a better way to make this hook-up stronger.
Comments or better ideas for this would be appreciated. Thanks joeearl.
Keep a pair of Piloti pull on driving shoes in the car.Not only will your carpets stay cleaner,and pedal slippage become a thing of the past,but you will also feel like Michael Schumacher on the way.They are available from Griot's Garage for less than $100.
Put the trans in neutral at a traffic light. Your foot won't slip off the clutch and it is also easier on the clutch. I have a 69 SS396 Camaro that I bought i 1971 with 9800 miles on it. Now after 76000 miles, it still had the original clutch in it. I never sit at a light with the clutch in on any stick shift car.
Go to Lowes or a skateboard shop and buy some nonskid tape. ...The type you see on stairs and skateboards. It should work great.
I put those bolts through the pedal to take pressure off my neuroma.
The neuroma's better, but I left the bolts alone because the grip is better. It looks weird and uncomfortable, but somehow it's not.
...did that on my '05 but haven't gotten to it on the '06 yet.
I appreciate your information on the Pilot shoes. The best shoes I found in a big shoe shop was bowling shoes, and that is what I have used when driving the Vette. Will be getting a pair of the racing shoes. I had looked for shoes of this type, but all of them have big, thick soles, and a good bit of overhang on the sides of the shoes. I tried a pair of them, and they were worse; because it is possible to accidentally get on the clutch and brake, due to the excessive width of the shoe soles. Thank you, very much. joeearl
I agree...long waits at traffic lights with your foot on the clutch pedal causes the throw out bearing to run continuously. Typically, the throw out bearing is a permanently lubricated bearing with finite life...it's purpose is to allow clutch disengagement during gear shifts. It doesn't make much sense to shorten it's life by running it at red lights.
