Can't Chirp 3rd gear?
Old Jul 18, 2006 | 07:09 AM
MJMJ's Avatar
MJMJ
Are you talking Dyno Tune? And what is TM?
Old Jul 18, 2006 | 08:06 AM
Ranger's Avatar
Ranger
Originally Posted by MJMJ
...And what is TM?
TM=Torque Management
The short answer is that the Stock Engine Control Module is programmed to reduce engine power during strong launches and shifts in order to protect the drive train. TM manifests itself in other conditions too, but its effect under strong acceleration is where owners focus.
TM is the primary reason why the C6 (400 HP) accelerates a bit slower than the 2002+ C5Z (405 hp). Generally the TM penalty in the quarter-mile is 2-3 tenths. That is, all other things being the same, a car with just TM tuned out will run the quarter 2-3 tenths faster.
Be aware that TM is a controversial topic. There are many doubter that it even exists. But they are wrong.
Here is a fairly typical Torque Management thread. Not a pleasant read. The facts are in there; but you have to squint a lot to find them.
Ranger
Old Jul 18, 2006 | 09:16 AM
Isaiah48's Avatar
Isaiah48
You hit the nail in the head, it is deffinetly more like a belt squeal. What is that?
It's exactly that; it's the serpentine belt squealing. Most of the vehicles I've had in the big pony range have done the same thing. You figure that all your accessories, such as your alternator and ac are spinning at 6500 rpm before you shift, then in an instant they are forced to drop 500 or so rpm. The inertia which was created from the accessories spinning makes the belt squeal just like your tires squeal on the road when you lock up the brakes. (that is; if you did'nt have anti-lock brakes)
The tensioner also relaxes instantaneously between shifts from the decreased load being placed on the belt, which compunds the the issue.
Old Jul 18, 2006 | 10:44 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Originally Posted by CYA-Vett
The non Z51 mn6 cars will run through the traps in 3rd (stock). Which is why I believe that non Z51 cars are just as quick in the quarter mile (one less shift).
Let’s just say that the lower gears come in handy: for less that ¼ mile runs. Normally the first 2 gears are all that’s needed. I think that goes a long way towards promoting that tranny. I tend to call that box the street racers delight.
Not me of course I out grew that sport in the early 70s.
Old Jul 18, 2006 | 12:34 PM
vette-oholic's Avatar
vette-oholic
you probably need new tires
Originally Posted by fastskyline
on a hard shift mine will spin 3rd until i let off
Old Jul 18, 2006 | 10:42 PM
Radical05's Avatar
Radical05
That is a good question because I can chirp my 3rd gear in my A4 shifting manually! You should be able to burn the tires off not just chirp.
Old Jul 19, 2006 | 12:24 AM
TMyers's Avatar
TMyers
I have had mine break loose shifting into third at the track. But this was in early spring track temps where in the 40's. This is stock but I think it really had to do with managing engine temps and having max power when the run was made. That first day we had 2 hour waits between runs more than enough time for cool down. Of course at the time I did not know that is what I was doing.
Old Jul 19, 2006 | 06:45 AM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Comp driving mode !
Old Jul 19, 2006 | 12:44 PM
vette-oholic
I am surprised at how many people can chirp 3rd and break tires loose??
let me ask this:
If you stomp on the gas in 1st, from a 5mph roll, do the tires spin (with traction control off)? mine sure don't - well they did when i needed new tires....
Old Jul 19, 2006 | 12:51 PM
6spdC6's Avatar
6spdC6
let me ask this:
O yeah with or without TC on.
FWIW I have hit at 20 with TC off and they will spin nicel y
Old Jul 19, 2006 | 01:03 PM
vette-oholic
If i didnt already have my car to the track, I'd be concerned that mines not as "fast" as it should be... but I got the right numbers there.
i wonder if TM is more evasive in some cars then others...
edit: oops, i meant invasive, not evasive.
Old Jul 19, 2006 | 01:18 PM
Ranger's Avatar
Ranger
...i wonder if TM is more evasive in some cars then others...
TM is an integrated element of the Engine Control Module. We know that the stock ECM program is updated periodically during each model year. But I've not seen posted any analysis identifying changes to the various tables affecting the behavior of TM. I suspect there were changes to TM between 2005 and 2006 and are differences each year between M6/M12 and A4/A6.
I've invested about 20 passes trying to find ways to minimize the effect of TM. But that's still a work in progress. The TM toll on the 1-2 and 2-3 shifts seems reasonably consistent. But the toll on launch is difficult to precisely differentiate from variation in launch rpm, clutch release, throttle squeeze and rack prep. But I certainly can feel TM cut power on the launch.
Ranger
