skip shift eliminator problem
Old Jul 19, 2006 | 12:09 AM
CLLOFF's Avatar
CLLOFF
Default skip shift eliminator problem
First thing I did to my 06 Coupe was to install a CAGS shift shift eliminator. $20 from one of the big Vette vendors. Worked great for 1,600m. Them my check engine light came on and stayed. Took the car to the dealer who said the diagnositic code was a power failure at the CAGS. Dealer said it was likely my skip shift eliminator. Sure enough we took off the eliminator and plugged the CAGS back in and the warning light was cleared.
So I am assuming my skip shift eliminator went bad some how. It's a pain if these don't even last 2,000 miles. Any one else with such an experience? Do these last? Maybe I got a lemon. I am temped to try it again.
Old Jul 19, 2006 | 12:14 AM
GMautotech's Avatar
GMautotech
The eliminator went bad. If you want you can make your own. Go to radio shack and buy a 2000 ohm resistor and either stick it into the skip-shift connector end or splice it into the harness.
Old Jul 19, 2006 | 12:25 AM
achilds's Avatar
achilds
I did the 2Kohm resistor instead of the cags eliminator. It is going on 5000 miles with no problems.
Old Jul 19, 2006 | 11:26 AM
darrylvandorn's Avatar
darrylvandorn
I had the identical experience as you at almost to the exact mileage. I also bought my CAGS eliminator from one of the big Corvette vendors. Maybe we bought ours from the same vendor and they got a bad batch from their supplier.
I also had the dealer remove mine.
Old Jul 19, 2006 | 12:30 PM
fenderowner's Avatar
fenderowner
Have had a CAGS eliminator kit from similar source on my C6 that I transferred over from my 04 C5. No problems to date (11,500 miles on the C5 and 4700 on the C6).
Old Jul 19, 2006 | 12:35 PM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
I have one on my 02 Camaro SS for almost 5 years and 30K miles and had it on my 94 Z28 for 7 years and 39K. So thats 12 years and 69K miles and everything is fine. Never had a problem.
Old Jul 25, 2006 | 03:04 PM
User B's Avatar
User B
Default Bad Eliminator
I had the same problem, same mileage. Got a second one from a different supplier (Zip) that looked different. New one works fine!
Old Jul 25, 2006 | 05:50 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
No flame intended, but if you guys would quit "granny" shifting, you'd never know that the CAGs was there. The PCM disables it at 20mph. (At least it has on my last 4 Corvettes)
Tom
Old Jul 25, 2006 | 08:13 PM
DJackman's Avatar
DJackman
You need to get a good quality CAGS elliminator. I got mine at Westcoast Corvette with more than 12000+ miles on it with no problem.
Old Jul 25, 2006 | 08:16 PM
DJackman's Avatar
DJackman
Tom
Try the L.A. commute here for a week and tell me if you still dont need one.
Old Jul 25, 2006 | 10:52 PM
Miaugi's Avatar
Miaugi
Tom
My granny would take issue with that statement!
You are right that the GAGS can be by passed with your right foot, but I got the bypass because I want to drive the car the way I want, and sometimes I just like to short shift and not have to worry about being forced to 4th...call me a granny shifter, I could care less...but at least I'm a happy camper now!!
Old Jul 26, 2006 | 12:54 AM
pattighe's Avatar
pattighe
2nd Gear
Default Installation
PURCHASED CAG MODULE WENT UNDER CAR TO INSTALL CANT FIND TRANSMISSION CONNECTION IS THERE LOTS TO REMOVE OR WHERE CAN I GET THE INFORMATION I HAVE A 2005 THANKS PAT TIGHE patmoetighe@aol.com
Old Jul 26, 2006 | 07:20 AM
Miaugi's Avatar
Miaugi
Sent you an e-mail....basically it is on the drivers side of the transmission near the rear of the tranny. It also has a label on the wire....it says "Skip Shift"! Take another look and I'm sure you'll wonder how you missed it.
Old Jul 26, 2006 | 08:45 AM
Gillvette's Avatar
Gillvette
Check out forum member Bugmans site for installation.
http://81x.com/bugman/c6
To skip shift eliminator problem
