B&M or Callaway?
Old Jul 26, 2006 | 07:10 AM
Miaugi's Avatar
Miaugi
I spoke to MTI yesterday, their shifter does sound promising but.....they do not have a specific C6 shifter. Although theirs will work in a C6, and it is a straight stick rather than having a bend (kink) in it, they are however looking to manufacture a model with the kink specifically for a C6.
So now I'm back leaning towards a Callaway....if only it was pricied more aggressively!
Old Jul 26, 2006 | 01:35 PM
cielosf's Avatar
cielosf
Default Six Shooter
Yes, the MTI is a true Short throw shifter. They claim 35% and it sure feels like it. It also accepts all *****. C5, C6 and anything with a 9/16 18 threaded ****.
Old Jul 26, 2006 | 03:19 PM
LOS ANGELES PI's Avatar
LOS ANGELES PI
Dude, why do you care where the "kink" as you call it is located????
You are misinformed, the shifter works in the c6 and c5, no difference whatsoever.
The reason why this shifter works so well is that the fulcrum of the product is located to the underside, beneath a thicker base plate, creating a shorter throw to the upper shaft of the unit.
It looks stock, doesnt rattle and is quiet as it uses the base boot from the OEM unit.
Jeeze, I should get a commission for this. You listening MTI ????
Old Jul 26, 2006 | 03:36 PM
gorillavet's Avatar
gorillavet
Careful, they will call you a Cheerleader
I don't know what that dude expects with the little kinks and all. I hope he understands the Callaway has no kinks either. The six shooter fits all C5 and C6's so what else do you need to know!
Old Jul 26, 2006 | 03:52 PM
tluck's Avatar
tluck
Ordered a MTI shifter yesterday.
Old Jul 26, 2006 | 06:34 PM
Miaugi's Avatar
Miaugi
You are misinformed, the shifter works in the c6 and c5, no difference whatsoever....
Gee, I spoke to MTI directly...but I should have just called you instead.
If you read my post I said I know the shifter works in the C6, but since the shifter is straight and doesn't have a "kink" in it, when it is installed the shift **** is not in the same location as the stock shifter. Also MTI told me they're working on a new shifter with a bend in it to "better" suit the C6.
Many things in life "will work" but that doesn't mean they are correct nor the best.
"gorillavet" I hope you got all that too dude?
Old Jul 26, 2006 | 07:11 PM
midnite902's Avatar
midnite902
I have not experienced the Callaway but I am happy with my B&M. The B&M greatly improved the shift. Shorter throw, more positive gates and a good feel. Negatives are it rattles/buzzes between gears. No rattles or buzzes in gear but on a "relaxed" shift there is a noticable buzz. This buss did not start until I had about 5k miles on the shifter.
The Callaway wasn't out when I purchased my shifter I selected the B&M over Hurst because I wanted to keep the OEM ****.
Old Jul 26, 2006 | 08:36 PM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I have the B&M and the vibrations occur when I wind out easy or hard. It also vibrates while in gear and cruising. I ordered the Calaway which, by the way, now will handle the OEM know.
Old Jul 26, 2006 | 10:09 PM
jbh2403's Avatar
jbh2403
So with all these folks changing over to Callway...anyway would could get a group buy... Callaway...you listening?
Old Jul 27, 2006 | 01:29 AM
2LT-Z51's Avatar
2LT-Z51
called MTI today.... guy told me C5 and C6 are the same shifter... they run them in all their C6's... i asked about the bend and he told me again that they run them in all their C6's and Z06's without any problems.....
i used to hit the radio with my hand with the stock shifter (hard shifting) and it had a bend... hard to believe that theirs will be a whole lot different without a bend... (i know it is a shorter shifter - but still - not like it had a bend in it)
oh well... i guess.... next...... anyone know about the stock C6Z06 shifter?? is that one a little shorter than a stock C6?
how about a pic of the MTI shifter in third...... (stock ball)
Old Jul 27, 2006 | 10:32 AM
Miaugi's Avatar
Miaugi
Originally Posted by 2LT-Z51
...i know it is a shorter shifter - but still - not like it had a bend in it...
It is shorter than the C5 stock shifter, but the same length as the C6 shifter.
Old Jul 27, 2006 | 11:30 AM
LOS ANGELES PI
I dunno. I think we need MTI to input here. It is a fulcrum point, not a kink. If you want a kink, Ive got an 800# for you to call.
Old Jul 27, 2006 | 11:38 AM
  #33
Miaugi's Avatar
Miaugi
800# I'm in....900#'s however are costing me a fortune!
Old Jul 27, 2006 | 04:27 PM
  #34
gorillavet's Avatar
gorillavet
Have you called Callaway yet? Did they tell you they don't have a kink either? You sound a bit too **** little feller
Old Jul 27, 2006 | 04:40 PM
  #35
Miaugi's Avatar
Miaugi
I see those PR course's are really starting to pay off for you!
Old Jul 27, 2006 | 05:21 PM
  #36
jbh2403's Avatar
jbh2403
So who has the best deal on the Callaway shifter?
