modified LS2 intake install
Old Jul 24, 2006 | 11:44 PM
healykid's Avatar
healykid
Default modified LS2 intake install
I'm a new member, but have followed the forum for some time. Last saturday went to CHarris85Vett's home in Bremerton to swap my stock LS2 intake for one of his ported units. He had a couple in stock, and each looked fine. Cory did most of the work, and I mainly got in the way. The work went well, and we had a lot of fun talking vettes and hotrods.
Isn't it funny in hotrodding when relatively small things make a difference? I've owned my 05 Z51 6 speed coupe for a year and a half. One of the first things I noticed with this car was a tendency to run rough and level off at WOT above about 5500 rpm (in stock trim). At first I thought that there was an engine/flywheel ballance problem, or possibly a tuning issue. However, I drove a friends 05' and it was the same as mine. Subsequently my car was modified (LG pros, high flow cats and x pipe, a 120/124 114 LSA comp cam from A&A, cleaned up stock heads w/ LS 6 valves, nice valve job, minor bowl work, milled 0.010, comp dual springs & ti retainers, Halltech ECM tune and CIA). Well the mod's took care of the falling off at higher RPM's, but some roughness up top remained. I don't know if any of the forum members have noticed this tendency. In my 40 some years experience with well built small block chevs, I've always had smooth pulling engines.
Cory's manifold seems to have cured most of the rough running at WOT up top. Hard to feel 7 to 15 hp (improvement?) at this horsepower level, but the motor seems to pull well. Will dyno in the comming weeks. Baseline dyno prior to mod intake was 398 RWHP and 375 TQ. Thanks Cory your a good man and a friend.
Old Jul 25, 2006 | 01:08 AM
glennhl's Avatar
glennhl
Hey, I think I found your rough running problem. I'm surprised your car would even run with only 120 and 124 degrees of duration. Sorry, I couldn't resist. I know it was a typo and you meant 220/224.
I haven't noticed the rough running up on top and stock my car pulled very strong to redline. I'm guessing maybe my stock manifold isn't as rough as yours was. I'd still like to get a ported manifold.
Thanks,
Glenn
Old Jul 25, 2006 | 01:21 AM
LOS ANGELES PI's Avatar
LOS ANGELES PI
Yes, Cory is a good guy. I have been waiting for some dyno intel.
However, all I have done is a tune and a Calloway CAI on my Z51 and got 365 rwhp after dyno and tune. Long tubes and fast cats are going on this weekend. No heads, cam or otherwise. So, the big Q is, does it work ??
Old Jul 25, 2006 | 08:21 AM
CYA-Vett's Avatar
CYA-Vett
Sure they work. Here is proof, no cooldown tricks like the others use. These pulls are 14 minutes apart.
+7.5 peak with 7-14 HP/TQ throught the power band.
Old Jul 25, 2006 | 09:20 AM
LOS ANGELES PI
Tell us more.
Your pulls were 15 minutes apart; you were able to r&r the intake in 15 minutes?
Im missing something.
Old Jul 25, 2006 | 09:24 AM
CYA-Vett's Avatar
CYA-Vett
14 minutes for 2 of us to r&r the intake. I can do it in 19 by myself. It took some practice, but I wanted dyno readings without cooldown.
Old Jul 25, 2006 | 01:24 PM
Cory@LS2PortWorks's Avatar
Cory@LS2PortWorks
St. Jude Donor '09
It was good to be able to contribute to your project and get some good chatting in while we were at it! I only wish it had been cooler... 88 degrees in the garage is less than ideal
I've very pleased that you are happy already. I'm a huge supporter of big power but only so long as it is driveable/enjoyable. We talked about a lot of stuff and I really look forward to seeing the results of your next step.
Keep in touch, Walt!
Old Jul 25, 2006 | 03:23 PM
PapaTango's Avatar
PapaTango
Default Inquiring minds....
Are you running the stock (90mm) throttle body and MAF? Have you removed the screens?
Old Jul 26, 2006 | 07:23 PM
healykid's Avatar
healykid
stock 90 mm TB and MAF, have not removed screens
To modified LS2 intake install
