Attention Vararam owners
Old Jul 27, 2006 | 08:48 PM
MJMJ's Avatar
MJMJ
Default Attention Vararam owners
I am installing my vararam snake charmer tomorrow on my 2005 C6 and I saw a post recently that showed step by step install instructions can someone please forward to me. Also do you need to take the hood off when doing the install? Anyway if anyone in the bucks county area is bored as hell tomorrow and wants to give a hand or just steer me in the right direction please shoot me an email mikem@pennfab.com
Thanks,
Mike
Old Jul 27, 2006 | 09:48 PM
yellowc6ohio's Avatar
yellowc6ohio
http://forums.corvetteforum.com/show...m&forum_id=101
Old Jul 27, 2006 | 09:52 PM
CYA-Vett's Avatar
CYA-Vett
You will be fine. Please remove the shroud before you cut it. It will take an extra 15 minutes but it's worth it.
Old Jul 27, 2006 | 10:44 PM
MJMJ's Avatar
MJMJ
Thanks for the tip!
Old Jul 27, 2006 | 10:49 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I didn't remove my shroud, it took just minutes to cut it, it was a piece of cake. In fact the entire install is very easy.
Here's my write up and track results with pics.
http://forums.corvetteforum.com/show....php?t=1434941
Old Jul 27, 2006 | 10:57 PM
dennis50nj's Avatar
dennis50nj
no you don't have to take your hood off. just take your time its very simple.
Old Jul 27, 2006 | 11:10 PM
06corvette's Avatar
06corvette
it is easy with the instructions provided with the vararam (new ones).
and you do not have to remove the hood.
if you have any questions about it any time you can PM me
Old Jul 28, 2006 | 09:50 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
imo, the install isn't all that difficult. no you don't need to remove the hood, just hope your back is up to the time and position, being stuck in that bent over position ain't getting easier on the ole back.
imo, the toughest part of the install is the mounting the lower 'scoop' piece. installing the support bracket isn't difficult but them darn screws that hold the scoop to the bracket. arrgghhhh.. otherwise it's pretty straight forward.
i don't know how you feel about modding mods but i removed the diffusor that was glued into the scoop when i installed mine.
Old Jul 28, 2006 | 10:06 AM
TXSTICK's Avatar
TXSTICK
I did mine last weekend. I used the precut shroud.
You might want to go to your local auto parts store and get some of theses. Retainers before you start. I cut mine off (did not have the tool to remove them) and put new retainers in during the reinstall.
http://www.scottsupply.net/Catalog/c..._fasteners.htm
You will not need them if you leave your shroud on and cut it.
Old Jul 28, 2006 | 10:37 AM
trumpet's Avatar
trumpet
I just installed mine on Wednesday. I ordered the pre-cut shroud and it was a serious pain to install. I thought I never was going to get the old one out. You have to lift the front of the car and pull the shroud out from underneath. But it's not as simple as the instructions made it seem. You really have to bend the nose out of the way to get the shroud thru there. I started to give up, sell it, and buy halltech or k&n style CAI. Luckily I persevered because I am happy with the final result.
Old Jul 28, 2006 | 10:51 AM
TXSTICK's Avatar
TXSTICK
I was going to take mine out the bottom but it was a real PITA.
With a little flexing of the shroud it came right out the top, I dont know why they said it would not. I should not of wasted time trying to take it out the bottom.
Old Jul 28, 2006 | 10:59 AM
MJMJ's Avatar
MJMJ
Wow, you guys have me really excited to do the install! I can't wait to get out there in the 90 degree humid sun
Old Jul 28, 2006 | 11:02 AM
CYA-Vett's Avatar
CYA-Vett
If you do decide to remove the shroud, it comes out the top. It is much easier to reinstall than remove so do not get discouraged if/when you remove it. You don't have to take it out to cut it, but it's a good safety measure. One slip and the AC condensor is trash. Just be careful, you'll be fine.
Old Jul 28, 2006 | 11:05 AM
mr 35th's Avatar
mr 35th
My install went great until I used my razor knife to cut the shroud...slipped and cut a nice hole in my ac condensor. That was a couple hundred bucks down the drain. SO take my advice. Get one thats precut or remove it and cut it.
Old Jul 28, 2006 | 11:17 AM
Abomination's Avatar
Abomination
if you take and slide a piece of plexiglass or sheetmetal between the shroud and the ac condenser before you cut its impossible to puncture it, thats what I did.
Old Jul 28, 2006 | 11:25 AM
TXSTICK's Avatar
TXSTICK
Only 90? Is it winter there?
To Attention Vararam owners
