Loud AC
Old Jul 28, 2006 | 02:57 PM
rsewell2's Avatar
rsewell2
7th Gear
Default Loud AC
Anyone else have a problem with loud almost siren like sound when engine is hot and ac is running full? Just started at 3000 miles. Local dealer says it is normal sound!
Old Jul 28, 2006 | 09:40 PM
99 torch red vette's Avatar
99 torch red vette
does it happen right around when you shift gears? (1-2,2-3)
because my car started doing the same thing 4 days ago (3590 miles)
seems when i turn the A/c down to try to hear it , it doesnt do it..
does it seem like it is comming from under the hood?
Old Jul 28, 2006 | 09:48 PM
Buffy's Avatar
Buffy
Double-check the outlet setting. Mine's quite loud when its set to bi-level (both dash and floor vents) and the fan is running fast. Much quieter when its just using the dash vents. Not that its exactly quiet at full fan anyway, but it does cool well so I can forgive that.
Old Jul 28, 2006 | 11:29 PM
rsewell2's Avatar
rsewell2
7th Gear
It happens when ac is running on high and is definitely coming from under the hood. It is so loud you can hear it half a block away.
Old Jul 28, 2006 | 11:34 PM
99 torch red vette
I have had the same thing happening now too..
Old Jul 30, 2006 | 11:20 PM
99 torch red vette
anyone else...
Old Jul 30, 2006 | 11:34 PM
Wayne88's Avatar
Wayne88
Originally Posted by Buffy
Mine's quite loud when its set to bi-level (both dash and floor vents) and the fan is running fast. .
I think that happens to mine too, as I don't use the AC too often.
I know if I just use the floor vents, its quiet.
Old Jul 31, 2006 | 01:27 PM
EuroRod's Avatar
EuroRod
Is it belt squeal? Perhaps the belt tensioner isn't doing it's job, and the belt is slipping under the compressor load. Just a thought?
Old Jul 31, 2006 | 02:49 PM
VET4LES's Avatar
VET4LES
That's a good bet. Mine has 11500 miles on it and it's been hot lately and I have no unusual noise coming from mine.
Old Jul 31, 2006 | 03:01 PM
UNKNOWN's Avatar
UNKNOWN
Banned Scam/Spammer
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
yep me.........happens only when ac on...but does not always
Old Jul 31, 2006 | 04:18 PM
keith5's Avatar
keith5
Active Streak: 90 Days
I was plagued with squeeling belts on my C5. I replaced the tensioners, etc. I eventually replaced all of the belts with Gatorbacks. That did it.
Old Jul 31, 2006 | 08:00 PM
99 torch red vette
it doesnt always do it, really only with the A/C on either high or close to it. It kinda feels like the car has some drag to it when you hear the noise..
Old Jul 31, 2006 | 09:00 PM
Prybar's Avatar
Prybar
I find the sound to be annoyingly loud on high with recirculate and the smell is not bad, but noticably irritating. It's really been stinking hot here so I'm running it constantly. Only 500 miles on my '07 so maybe it needs a little more breaking in.
Old Jul 31, 2006 | 11:02 PM
rsewell2's Avatar
rsewell2
7th Gear
Sound is definitely coming from motor. It happens when a/c motor kicks into high gear. Dealer actully simulated this and happened when motor was at 80%. Once that happened, dealer said, yep, that is normal happens on every 06 vette. Until, I can get to a different dealer, I guess I will just wait and hope a/c moter goes out all together and get a new one.
Old Aug 3, 2006 | 09:46 PM
99 torch red vette
any news on your A/C mine is getting anoying...
I am calling the dealer tomorrow
Old Aug 15, 2006 | 09:37 AM
99 torch red vette
HELP!!
I went to the dealership this morning and now it won't make the noise for them to hear..
anyone have this same issue?
Old Aug 15, 2006 | 11:34 AM
web1's Avatar
web1
ha..for a minute there, I thought someone installed a turbo charge under my hood while I was away. yes...it makes a loud noise
Old Aug 22, 2006 | 10:53 AM
99 torch red vette
TTT...........
HELP, I need someone to tell me if they had this problem and the solution...
To Loud AC
