Down shifting and mileage
Old Aug 4, 2006 | 09:56 PM
Bisha's Avatar
Bisha
Default Down shifting and mileage
I have a 2006 C6 and my habit has always been to downshift when coming to a stop to save the brakes a bit and keep the vehicle in a gear where there was quick power if it was needed. I have been watching the instant mileage numbers that are shown in the display and find that as I downshift the mileage declines even with my foot off the gas. Does the engine just suck in extra fuel because of the higher revs even though no gas input is being given or is the instant read numbers just some false reading due to however the cars computer computes the mileage?
Thanks for any advice or opinions.
Neil
Old Aug 4, 2006 | 10:05 PM
haljensen's Avatar
haljensen
Downshifting to help slow down made sense when I first started driving, drum brakes weren't too good. Now with inexpensive disc brakes it doesn't make any sense to use the gears to slow down.
Brake pads are cheap and easy, clutches and transmissions aren't. Around town I'll shift to nuetral before I brake, I like watching that average mileage build up (600 no load RPM and 40 MPH).
Old Aug 4, 2006 | 10:16 PM
johnodrake's Avatar
johnodrake
Moderator
I downshift -- not to save brakes, but because I like to shift. That's why I have the 6 speed manual!
Old Aug 4, 2006 | 11:50 PM
VET4LES's Avatar
VET4LES
I enjoy every shift.
Old Aug 5, 2006 | 12:16 AM
Wayne O's Avatar
Wayne O
CF Senior Member
That's a good question. I don't know exactly but my guess would be there's a slight decrease in gas mileage by 'the practice of' downshifting. You're bound to downshift and hit the gas pedal at least some of the time (rather than downshifting and always coasting-down to a stop without ever touching the gas pedal). Even downshifting and never touching the gas pedal I would think you're still running the engine at a higher rpm level...??
For me, the last reason in the world I have a C6 is to worry about gas mileage....I like shifting gears.
Old Aug 5, 2006 | 07:35 AM
V Vette's Avatar
V Vette
Really no reason mechanically or performance wise to down shift. It also wastes gas! Brakes are cheaper then clutches. However, down shifting to lower gears will help in emergency stop situations..
Old Aug 5, 2006 | 07:51 AM
bradb's Avatar
bradb
St. Jude Donor '06-'07
Drive like Granny: Coast to a stop in neutral
Drive like a man: Downshift to correct gear for the speed before stopping
Drive like a pro: Use stopping to practice your heel and toe
As for saving gas, if that is your number one concern, you would be on a hybrid forum, not the Corvette Forum.
- disclaimer: The above comments are my personal opinons and not meant as an insult to any individual, gender or group. No Corvettes were harmed during the evolution of my opinions -
Old Aug 5, 2006 | 09:11 AM
Walt White Coupe's Avatar
Walt White Coupe
The ever so slight decrease in gas milage by downshifing as you slow down is more than overcome by the increase in safety by having the car in a gear where you can use the power to avoid an emergency situation if needed.
Old Aug 5, 2006 | 09:56 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
It sounds so good when you do correct downshifting when slowing down. Those Corsa Sports sound off real nice.
Then a few seconds later they sound off going back up to speed
Old Aug 5, 2006 | 10:36 AM
6 speed Sid's Avatar
6 speed Sid
An old road racer told mem years ago, breaks are cheaper than engines and clutches.
Old Aug 5, 2006 | 10:37 AM
6 speed Sid
An old road racer told me years ago, brakes are cheaper than engines and clutches.
Old Aug 5, 2006 | 07:05 PM
2BBVette's Avatar
2BBVette
I downshift and break at the same time Also, I never take the car out of gear unless its a long light. Drive your car how you feel comfortable. Everyone who drives manual has their own stlye. Sometimes when I'm downshifting just one gear I tap the throttle then there is no engine breaking...... Do your thing.
Old Aug 5, 2006 | 07:06 PM
2BBVette's Avatar
2BBVette
Old Aug 5, 2006 | 07:47 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
To Down shifting and mileage
