Throttle Body Spacer
Old Aug 4, 2006 | 10:55 PM
Kenny94945's Avatar
Kenny94945
Default Throttle Body Spacer
There is a product that is about an inch thick that bolts to the front of the TB.
Is this a mod that goes on with out any difficulties?
Such as, the accordian tube and the rest of the filter intake, does it just fit right or do these components need to be modified or/and do they get "cruched up?.
Price for this mod at $60 seems OK.
Old Aug 4, 2006 | 11:06 PM
not08crmanymore's Avatar
not08crmanymore
Default spacer
Yea,i'd like to know too since i just got one...although i'm sure it's got directions.
Old Aug 4, 2006 | 11:41 PM
purple heart's Avatar
purple heart
If it's made of rubber, it WILL get crunched up-unless they have a metal sleeve inside of the opening or around the outside of the spacer. Have seen one removed and it DEFINITELY crunches up.
Old Aug 5, 2006 | 12:16 AM
bunk22's Avatar
bunk22
I've got one and it's an easy install. I thought as well, for $60, might as well try it. To be honest, I have no clue if it did anything. It didn't increase or decrease my track times so pretty much what I've got is hard rubber spacer.
Old Aug 5, 2006 | 01:55 AM
shurite44's Avatar
shurite44
It is not hard at all to install. And you just need to torque the bolts properly and it fits fine.
There was someone who fabricated or found some metal tubes to fit inside the vararam spacer so you could torque the bolts down tighter. I don't have a problem with how it fits though.
Old Aug 5, 2006 | 08:42 AM
not08crmanymore
Default bolts
Ok,and how would I find out if the bolts are torqued down properly???How do I do that??
Old Aug 5, 2006 | 09:14 AM
dennis50nj's Avatar
dennis50nj
just snug, no leaks,tighten evenly use your own judgement.
Old Aug 5, 2006 | 09:46 AM
TXSTICK's Avatar
TXSTICK
It has metal inserts that go in to the bolt holes of the spacer, very easy to install.
Old Aug 5, 2006 | 12:10 PM
not08crmanymore
Default info..
thanks for the info...oh man,I feel the mod bug nibbling away at my willpower to not mod, i'm in trouble now....
Old Aug 5, 2006 | 01:34 PM
Abomination's Avatar
Abomination
the new one has metal spacers built into it.
Old Aug 5, 2006 | 02:23 PM
shurite44's Avatar
shurite44
Not sure what to tell you on that one. Seemed fairly easy to me, just common sense I guess.
What exactly is it that you are having problems with, that may be an easier way to tackle the problem. Do you have a bad seal?
Old Aug 5, 2006 | 04:19 PM
not08crmanymore
Default spacer
no problems.haven;t even gotten it yet,I just thought that there was a specific torque # OR SOMETHING THAT The wrench would have to be turned to when tightening.I'll just tighten it till it feel secure...
Old Aug 5, 2006 | 04:28 PM
shurite44's Avatar
shurite44
If I took a guess I would say we put about 7 lbs of torque, maybe a little less. Some people are saying the new ones have metal sleeves like the ones a member was suggesting a while back.
If that is the case I would say it should not be a problem. I have to be honest, I really don't know if mine had those metal sleeves or not.
I just put on a ported TB so I just had the thing off yesterday. Wish I would have looked to see if I had the metal sleeves.
Old Aug 5, 2006 | 04:56 PM
not08crmanymore
Default Tb
Notice any difference with the ported throttle body??90MM??
Old Aug 5, 2006 | 04:58 PM
shurite44's Avatar
shurite44
Not sure, I will race next Wednesday and should be able to see a little in the 60 foot time I hope.
Old Aug 5, 2006 | 05:43 PM
not08crmanymore
Default tb
Let me know after the race.Did you just do the TB or other stuff too??
Old Aug 5, 2006 | 05:52 PM
excessive81's Avatar
excessive81
back away from the tq wrench.....jk
To Throttle Body Spacer
Old Aug 7, 2006 | 10:15 AM
kelp's Avatar
kelp
The guy selling the aluminum TB spacers can't be reached on his link anymore. Does anyone know how to contact him?
Old Aug 7, 2006 | 10:23 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
i have the same question. the current way the intake ducting, maf, and bellows all connect to the throttle boy has everything aligned and conected with just enough length. if i add a spacer, which will move everything else back (or forward - depends upon how you are looking at it) an additional inch or so, how does everything else line up properly ? are folks using a shorter bellows ?
Old Aug 8, 2006 | 06:09 PM
not08crmanymore
Default Tb Spacer
OK,GOT MINE TODAY!!Now,it came with long black bolts/screws.This thing goes in front of the TB,like somebody said???Looks more like it would fit behind it!!How do i tell if it's the newer version??there's no metal or anything in the screw holes...
