Trap Speed
Old Aug 6, 2006 | 01:47 PM
Stingray23's Avatar
Stingray23
Default Trap Speed
Assuming the manual Z51 cars typically trap between 115-115.5 mph, what would the car trap at with a Heads/cam/intake? Or roughly 100-130 hp more?
Old Aug 6, 2006 | 10:25 PM
cbrf4i1's Avatar
cbrf4i1
every 10hp is around 1 mph, if you can get 100-130 head/cam/intake that would be about 10-13mph. if would be easier hit 130 with some exhaust work.
Old Aug 7, 2006 | 04:30 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
I would think it would be closer to 121-122MPH. I added about 100RWHP and only picked up .6 seconds and 8 MPH. Keep in mind that traction and gearing plays a HUGE part in trap speed.
Old Aug 7, 2006 | 08:35 PM
yell03's Avatar
yell03
First off, average C6s (Z51 or non-Z51) usually trap:
Manuals - 113-115 (12.2-12.7)
Automatics - 110-113 (12.4-12.9)
Now to answer you question:
Yes 10hp equals 1mph and 0.1 second in a perfect world, for instance a C6 Z06 has about 100 more horsepower and typically runs 11.2-11.7@124-127mph, the average being 11.5-11.7@124-125.
So as you can see yes 100hp = 10mph & 1 second in a perfect world, but that is taking in to account much more traction from the Z06s 325 rear tires compared to the C6s 285s.
Add 100hp to a C6 and the stock tires will surely not provide adequate traction and you might end up running short of those gains as RichieRichZ06 pointed out.
Howard
Old Aug 7, 2006 | 10:10 PM
cbrf4i1's Avatar
cbrf4i1
the original poster didn't provide what kind of tires he will be using, therefore i will have to assume if you are going to add 100-130hp to your car, you must have also improve traction also. keep in mind i said 10hp is "around" 1mph. keep in mind in richie's case gain 8mph from 100hp, that is .8mph per 10hp, i consider it around enough. don't you think so?
To Trap Speed
