Installed the FAST LSX intake
Old Aug 12, 2006 | 01:36 PM
Blue02Z06's Avatar
Blue02Z06
Originally Posted by LS2 Pontiac GTO
Did you use the FAST MAP sensor adaptor?
Ive heard this is not a requirement if using the stock 90mm throttle body. Is this true?
Dave
Old Aug 12, 2006 | 01:47 PM
xstang's Avatar
xstang
Dave
The Map sensor is located on the front of the LS2 intake but was initially located on the back of the FAST intake (same as the LS1/LS6) It has to be "moved" and secured... The back of the fast has to be plugged so it won't leak because of the old location... If you look at the pictures, you will see the red metal circle piece. That hold the map sensor in the front of the FAST.. The kit I purchased was from Lingenfelter...
Lingenfelter MAP Relocation Kit # LN-BK28KIT
Old Aug 12, 2006 | 01:51 PM
Blue02Z06's Avatar
Blue02Z06
Originally Posted by xstang
The Map sensor is located on the front of the LS2 intake and the back of the FAST intake. It has to be moved... If you look at the pictures, you will see the red metal circle piece. That hold the map sensor in the new location.. The kit I purchased was from Lingenfelter...
thanks Rick, i appreciate the help.
Ive got everything for my Head/Cam install sitting in my room, now just cant figure out where to purchase the fuel rail adapters and a new UDP Bolt. Im glad i purchased the MAP kit and the Firewall kit already.
Dave
Old Aug 12, 2006 | 01:58 PM
xstang's Avatar
xstang
Dave
Check your PM..
Old Aug 12, 2006 | 04:45 PM
LSX Performance's Avatar
LSX Performance
So you didnt have to splice any wires for the MAP sensor right?
What do you do about the hole for the MAP sensor in the rear of the manifold?
Old Aug 12, 2006 | 05:11 PM
xstang's Avatar
xstang
The Lingenfelter kit comes with a plug....
