Best Mods for adding Horsepower
Old Aug 9, 2006 | 05:17 PM
furniss5's Avatar
furniss5
Default Best Mods for adding Horsepower
What are the top 3 best mods for adding horsepower without adding superchargers/turbo/prochargers ?
Starting with the factory Car.
Charlie
Old Aug 9, 2006 | 05:29 PM
johnodrake's Avatar
johnodrake
Moderator
Headers/Cam/Heads
Old Aug 9, 2006 | 05:30 PM
teazr1's Avatar
teazr1
You'll get a lot more respones if you look in the tech section. There are tons of threads in there on this topic.
Old Aug 9, 2006 | 05:43 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
1. Camshaft. This is THE MAJOR determinant of engine performance.
2. Heads. Better breathing.
If you do 1. and 2., then 3. is mandatory:
3. Excellent tune by a skilled tuner.
Old Aug 9, 2006 | 05:53 PM
jjohn918's Avatar
jjohn918
Long Tube Headers
Cold Air Induction
Cam
Tune
Old Aug 9, 2006 | 09:40 PM
alamo1974's Avatar
alamo1974
Get the Procharger, I did the 3 recommended and I would have been better off w/ the Procharger.
Old Aug 10, 2006 | 12:58 AM
1320fan's Avatar
1320fan
Although it won't add horsepower, 3.90 rear will liven up the car.
Old Aug 10, 2006 | 01:42 AM
Camaro4Life's Avatar
Camaro4Life
first you need money.............. many, many moneys.
just a tip
Old Aug 10, 2006 | 02:04 AM
blkvc6's Avatar
blkvc6
Default Mods
Charlie
I asked Dick Gulstrand ( Legendary Corvette Racer) the exact same question at a Corvette function in South Lake Tahoe a few months back. His response was #1) Exhaust w/ X-pipe ( i went with Borla Stinger ) #2) Air induction( He recommended Black Wing) #3) As 1320 responded in this thread--Rear end gearing. I have been told by track people that the rear end change has the most impact as far as noticable feel off the line and track. If Gulstrand recommends it then it's sure as hell good enough for me!! i've got two to go and the rear gear change is next ( hopefully in the next two weeks). HAPPY MOTORING, Steve
Old Aug 10, 2006 | 07:00 PM
Moto's Avatar
Moto
Just add NOS and call it a day.
Old Aug 10, 2006 | 10:00 PM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
I effectively did all three on my C5 and got great results. I checked your profile and I guess that you have the base coupe with the 3.42 rear end. If this is the case, you will be amazed with the gear change. However, if you have an MZ6 transmission on the Z51 option, then your transmission is giving you apprximately the same results as a stock coupe with 3.90 gears. I wouldn't recommend replacing the 3.42 gears on the Z51. Overall, I liked my 4.10's better than these 3.90's but I'm not going to make any changes for just that difference. And remember, there's a warranty issue as well.
Old Aug 11, 2006 | 02:47 AM
blkvc6's Avatar
blkvc6
Default mods
Fundriver, Appreciate your feedback. According to my build sheet it shows 2.56 axle. I've got F55 w/FE2 Base suspension. i drove my buddies 99 FRC and he has 3:44 which he says came from factory. Even though he has 50HP less there is a big difference in the pop factor he has off the line than i do. i do agree with the danger with the warranty issue, but after driving his i am getting greedy!!
Old Aug 11, 2006 | 02:52 AM
shopdog's Avatar
shopdog
Charlie
1)Nitrous
2)Dual stage Nitrous
3)Progressive Nitrous
Old Aug 11, 2006 | 02:56 AM
Atomic Punk's Avatar
Atomic Punk
true...
Old Aug 11, 2006 | 11:52 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Originally Posted by jjohn918
Long Tube Headers
Cold Air Induction
Cam
Tune
Old Aug 11, 2006 | 12:52 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Long Tube Headers
Cold Air Induction
Cam
Tune
oh yeah and nitrous of course
Old Aug 11, 2006 | 12:54 PM
0Cajun @ Edgyvette
Former Vendor
Definitely not questioning Mr. Gulstrand's opinion however the catback will get you about 3-5 and the blackwing is one of the lower gaining air intakes. The rear end will not get you any more HP/TQ it will just get you out of the hole quicker. In fact it may rob top end if you go with too low of gear. Of course if you are happy then that is all that matters. The bright side is that with those mods you dont even need a tune.
To Best Mods for adding Horsepower
Old Aug 11, 2006 | 01:01 PM
Sales@HPE's Avatar
0Sales@HPE
Former Vendor
There's alll sorts of stuff you can do. Our C5 Big Box of Goodies works on a C6 with just some minor parts tweaking...
Old Aug 11, 2006 | 01:08 PM
Geneus's Avatar
Geneus
May I suggest the Z06 mod?
Old Aug 11, 2006 | 02:23 PM
blkvc6's Avatar
blkvc6
Default Mods
I do agree with your statement on the blackwing as it would not be my first choice either. My build sheet shows 2.56 axle and after driving my buddies C4 w/ 3.44 it kinda got me excited. Im not sure what the right gear set-up would be to have best of both worlds, but most of the thrill is in the pull in lower gears! The last time i had fun on the top end side i beat the NSX but got the ticket!! Appreciate the feed back, Thanks, Steve
