B&B X-pipe clamp question
Old Aug 11, 2006 | 09:03 AM
AFVETTE's Avatar
AFVETTE
Default B&B X-pipe clamp question
I bought a used B&B X-pipe and installed it yesterday. Does it require clamps where the two sections join? I didn't receive any.
Tom
Old Aug 11, 2006 | 09:26 AM
Festivus's Avatar
Festivus
Can't you just use the stock ones? If not call B&B and have them ship you out a set. I don't have the PRT section but used the stock set when connecting the back pipes up and they worked fine.
Old Aug 11, 2006 | 09:39 AM
AFVETTE's Avatar
AFVETTE
There isn't any left over parts to re-use. The stock clamps are used where the over the axel pipes join the rear of the x-pipe. The oem h-pipe is one piece unlike the B&B X-pipe which is two sections. The clamps on the oem H-pipe are welded on and I don't want to remove them if I don't have too.
I'm just not sure clamps are needed, but since buying used I have no way to know. I'm hoping someone with the B&B X-pipe will chime in.
Tom
Old Aug 11, 2006 | 09:44 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
PM Hoffie or VetteJoel. They have installed 20+
Old Aug 11, 2006 | 10:01 AM
AFVETTE's Avatar
AFVETTE
Thanks for the tip. Just PM'd VetteJoel.
Tom
To B&B X-pipe clamp question
