**New DTE Differential Component- 20-disc Clutch Pack**
Old Aug 16, 2006 | 11:54 AM
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
Default **New DTE Differential Component- 20-disc Clutch Pack**
DTE Heavy Duty 20-Disc Differential Clutch Pack Upgrade Kit
The C5/C6 Corvette is an outstanding performance platform in stock trim, but reveals it’s differential weaknesses quickly when additional power is added. The stock 16-disc clutch pack design often burns up and fails under high powered applications, during burnouts or when used in racing. Replace the weak, worn or damaged stock 16-disc clutch pack in your Corvette’s differential with our direct replacement, HD 20-disc clutch pack upgrade kit! This component provides additional posi-traction clamping load and friction surface area over stock parts per side, which improves chatter-free cornering accuracy for road racing, while also enabling a straighter launch at the strip. Upgrade the weak O.E. differential clutch pack with a track proven clutch pack design from DTE today, for which there is NO substitute!
Application
1997-2004 C5 Corvette differential w/ any gear ratio or trans.
2005-'06 LS2 C6 Corvette differential w/ any gear ratio or trans.
Upgrade Kit Includes:
- 10 cryogenically treated HD friction discs
- 10 cryogenically treated & micro-polished HD steel discs
- 2 cryogenically treated & micro-polished DTE engineered HD clutch pack preload springs
- DTE decals
$269
These kits are in production now and should be in stock fully within a couple of weeks or so- which is in plenty of time for the fall weather racing season.
DTE
