Corsa Heat
Old Aug 17, 2006 | 09:39 AM
MN6Z51's Avatar
MN6Z51
Default Corsa Heat
Had my Corsa Sport Installed last night. Love the sound, but noticed that the cockpit is a little toastier now. Oil temp seems to also be about 10-15 degrees higher than I can remember around 230. Anybody have an idea as to why this may be happening? Could this also result in more oil being burned?
Old Aug 17, 2006 | 09:50 AM
Irv's Avatar
Irv
My guess - the cool new exhaust sound is causing you to drive more aggressively, raising the oil temp and making the cockpit more toasty.
Old Aug 17, 2006 | 10:11 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Your in a happy mode and your senses are in overdrive. Doubt anything has changed at all (temp/oil use). Weather conditions can do some funny things. Example a temp change of ten degrees is good for a 1# change in tire pressures.
Enjoy your car and relax.
Old Aug 17, 2006 | 10:15 AM
Wayne88's Avatar
Wayne88
Old Aug 17, 2006 | 10:16 AM
MN6Z51's Avatar
MN6Z51
I know stock exhaust is a double wall construction, insulating exhaust heat a little bit more. Is Corsa double wall?
BTW- What is normal oil temp anyone experiences who has Corsa Sport?
Old Aug 17, 2006 | 10:47 AM
Walt White Coupe's Avatar
Walt White Coupe
Exhaust system change will have absolutely no effect on what you are describing. Look elsewhere if changes are real.
Old Aug 17, 2006 | 11:15 AM
shurite44's Avatar
shurite44
Not the exhaust.
Old Aug 17, 2006 | 03:53 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
It's not the exhaust....if you're truly experiencing higher engine temps & not just higher ambient, check someplace else. BTW....I installed an Elite ceramic chassis plate at same time as the Corsa Sports & it did help to keep down convection heating in the interior.
To Corsa Heat
