Sensor mounts
Old Aug 18, 2006 | 11:40 AM
whod's Avatar
whod
2nd Gear
Default Sensor mounts
Can anyone lead me to the answer of mounting air pressure sensors in aftermarket wheels, namely Asanti wheels? Thanks in advance for the help.
Whod
Old Aug 18, 2006 | 06:58 PM
BEZ06's Avatar
BEZ06
Whod
Hi Whod
Here's a picture of a sensor (this is an old style that was never designed to be mounted in the valve stem hole) that is being "banded" or "strapped" inside the wheel with a large hose clamp:
Forum member C6Dude "banded" his sensors in his aftermarket wheels. Most people use a long metal hose (or duct) clamp, but C6Dude used a long tie wrap and some glue. It is said that the valve stem is part of the antenna for the sensor, so you shouldn't cut it off - but many people have cut off the valve stem without any problems. You should probably leave it on if the sensor will mount without taking it off. If they are banded in the wheel they are usually mounted 180 degrees opposite from the valve stem. You need to know where they are so you can excite them with a TPM Tool.
Take a look at this thread and you'll see a picture of C6Dude's banded sensor (he also epoxied them to the wheel):
Tire Pressure Sensor and TPM Tool 101
If you're interested in any more info on sensors, here are a cople other threads:
Video Using a TPM Tool to Check Sensors
Video Using a TPM Tool to Register Sensors
Bob
