Knocking sound when turning right.
Old Aug 21, 2006 | 06:48 PM
linusVette's Avatar
linusVette
Default Knocking sound when turning right.
Every time I take a right turn, I hear a knocking sound like something is loose behind the left rear q-pannel. It also sometimes sounds like it is coming from the seat. Anyone have a similiar issue?
Old Aug 21, 2006 | 06:59 PM
Crash Test Joey's Avatar
Crash Test Joey
Sometimes when I get in and out of the car, I can hear the seat itself moving in the seat track. It sounds almost like a popping or knocking sound, simliar to the noise you'd hear, say, by folding a plastic milk jug in on itself. Maybe that's what you hear.
I can duplicate it by sitting in the driver's seat and pushing backward with both feet on the floor. You could try that and see if your seat makes the noise. I don't know if it's the seat/track assembly, or where the seat bolts to the floor (I know my C6 has a much different floorpan than any GM car I've owned, it may be the floor itself "popping" under the weight).
Old Aug 21, 2006 | 07:05 PM
linusVette's Avatar
linusVette
Yeah, I did the same and hear the noise at times. However, not all the time . Did you do anything to correct the sound?
Old Aug 21, 2006 | 08:30 PM
outnumbered's Avatar
outnumbered
Just a shot in the dark.Check your rear stabilizer bolts.many have been found loose.Usually it is the top left bolt.Mine was 1/2 way out.
Or could it be coming from the differential? There has been a lot of them
clunking.Mostly when cold and at low speed turns.
Old Aug 22, 2006 | 07:32 AM
Wayne88's Avatar
Wayne88
Originally Posted by outnumbered
Just a shot in the dark.Check your rear stabilizer bolts.many have been found loose.Usually it is the top left bolt.Mine was 1/2 way out..
A few weeks after I installed the Corsas, I got an occasional thumping sound.
It was the rear sway bar, it needed to be re-torqued.
To Knocking sound when turning right.
