XM Module Question
Old Dec 21, 2006 | 12:55 PM
mr1960's Avatar
mr1960
Originally Posted by GentleBen
I have a non-Nav radio (1 SB in an '05 coupe) into which I installed an XM module from and '06 Vert. Same symptons as yours but I had the local Master Corvette Mechanic reprogram the BCM in the car and the XM module has worked ever since.
I would tend to think that the Nav radios, also operating on the CAN bus would require the same reprogramming to activate the XM module.
Could you give me the contact info of the Master Corvette Mechanic? My dealer could not get my module unlocked. Maybe they can call yours.
Thanks,
Old Dec 21, 2006 | 01:01 PM
GentleBen's Avatar
GentleBen
Cruise-In 7-8-9-10-11-12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Joe Malo at Koons Chevrolet in Tysons Corner, VA.
Old May 15, 2010 | 10:56 PM
GXP25's Avatar
GXP25
*BUMP* for anyone searching around for an answer.
There is a fix and it is all outlined in the following thread:
http://forums.corvetteforum.com/c6-c...-resolved.html
The module can be "unlocked."
