How do you pull DTC codes on C6
Old Sep 4, 2006 | 07:07 PM
kirbyloid's Avatar
kirbyloid
Default How do you pull DTC codes on C6
Old Sep 4, 2006 | 07:51 PM
Miaugi's Avatar
Miaugi
If you were looking for a "how to" like on a C5, I think GM closed that door!
As far as I know you can only do it with an OBDII scanner....and even for that there have been some changes where you may need a new model that supports "CANBUS", at least I think that is what it's called.
Old Sep 4, 2006 | 07:55 PM
VET4LES's Avatar
VET4LES
There are several good one's available, I have the Innova 3110 that works great but there are others also.
Old Sep 5, 2006 | 02:08 AM
BlackZ06's Avatar
BlackZ06
I don't know why GM took the feature away of displaying them on the DIC like a C5 can, but apparently they did. The interface for the C6 is called CANdi.
The LAN that the computers used in a C5 to talk to each other has been upgraded from Serial 2 to a (GM name for it) Controller Area Network (CAN) for the C6. To talk to it, scan tools like the Tech 2 that your GM dealer hooks directly to the C5 netwwork now needs a CAN digital interface (CANdi) box to talk to the C6 networked computers.
To see more about the GM scan tool (Tech 2) take a look at:
http://www.vetronix.com/aftermarket/
and click on SCAN TOOLS in the list on the left.
There are other 3rd party vendors such as AutoTap ( http://www.autotap.com ) that make interfaces for the GM system, just be sure to add on the necessary hardware for the CAN in your C6
To How do you pull DTC codes on C6
